1. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
ryanskiheadJan 16, 2017 1:15 PM (in response to factorym80168970)
1 person found this helpfulShould be fixed now. I triggered a rebuild on your app and that error is gone. I see that a new error is triggered however ... it seems like your certificate is invalid. Have a look at the build log and check out the links output by the build log.
2. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
factorym80168970 Jan 24, 2017 5:27 PM (in response to ryanskihead)issue started resurfacing after i updated the code
3. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
factorym80168970 Jan 24, 2017 5:34 PM (in response to factorym80168970)Strangely it worked after i did the build couple more times
4. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
factorym80168970 Jan 31, 2017 2:42 PM (in response to factorym80168970)issue again started resurfacing after i updated the code. This time re-building does not help either.
6. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
wellingtonz92777242 Mar 22, 2017 10:47 AM (in response to factorym80168970)same error
- App ID
- 1724265
7. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
vellu81 May 8, 2017 6:33 AM (in response to ryanskihead)We have the same problem with app ID 2546421 windows build and we have now tried everything. Phonegap team, please check this out.
8. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
vellu81 May 9, 2017 12:58 AM (in response to factorym80168970)Today build is working
9. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
jasonn85191080 Jun 27, 2017 3:01 PM (in response to factorym80168970)Having same error
CertUtil: The system cannot find the file specified.
My "Personal"
CertUtil: -delstore command completed successfully.
My app id is 2545322
10. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
johannesh26176335 Mar 10, 2018 2:30 PM (in response to ryanskihead)We're facing this issue since weeks now.
We're desperately looking for a solution to this, since we have a scheduled go-live in the coming week.
Would you mind looking into it?
The App ID is 2110758
11. Re: Windows 10 Release Build error:CertUtil: -importPFX command FAILED: 0x80070002 (WIN32: 2 ERROR_FILE_NOT_FOUND)
adrianb47263084 Mar 15, 2018 3:48 PM (in response to johannesh26176335)We are having the same problem - same error. App ID is 304700.
No amount of retries will get the build to complete.
Can someone at PGB please resolve this.
