0 Replies Latest reply on Jan 17, 2017 6:04 AM by jessevic
    Checkbox with multiple selections. Write selections to Properties field
    jessevic Level 1
      Hello all,
      I have less experience of javascript but from time from time I can reach easy targets with javascript. Now, I have another problem.
      I have to run a sequence and the task is: show a check mark box with 7 possible check marks. Take into account that you must be able to select multiple check marks.
      The values (the text (description)) has to be reflected to the document properties: "Title". If you selected multiple check marks, there must be a ";" between selection 1 and selection 2.
      It would be great if somebody can set me on the right direction.
      At this moment, this is the temporary code I tested, but the result is (of course) not correct.
      // Dialog Definition
      var oDlg = {
              strName: "test",
              cB: "",
              initialize: function(dialog) {
              dialog.load({"usnm":this.strName,});
          commit: function(dialog) {
              var data = dialog.store();
                      this.strName = data[ "usnm"];
              checkB: function (dialog){
                  this.cB = data["chk1"];
                  console.println("CB fct " + this.cB);
          description: {
              elements: [ {
                  type: "view",
                  elements: [
                      name : "Enter the type(s) of manual (e.g. Installation manuals, Operation manuals, Installer reference guide, User reference guide, General safety precautions, Declaration of Conformity, Option handbooks) (use ; if you must select several type of manuals",
                      type: "static_text"
                      item_id: "usnm",
                      type: "edit_text",
                      char_width: 30
                                      item_id: "chk1",
                                      type: "check_box",
                                      item_id: "chk2",
                                      type: "check_box",
                                      item_id: "chk3",
                                      type: "check_box",
                                      name: "Installer reference guide"
                                      item_id: "chk4",
                                      type: "check_box",
                                      name: "User reference guide"
                                      item_id: "chk5",
                                      type: "check_box",
                                      name: "General safety precautions"
                                      item_id: "chk6",
                                      type: "check_box",
                                      name: "Declaration of Conformity"
                                      item_id: "chk7",
                                      type: "check_box",
                                      name: "Option handbooks"
                      type: "ok_cancel",
      if( "ok" == app.execDialog(oDlg)) {
             this.info.title=oDlg.cB;
      this.info.author=""
