2 Replies Latest reply on Jan 17, 2017 8:30 AM by cbishop01
    Indesign Template Question?
    cbishop01 Level 2
      Is there a way to keep the file name of the template?  RIght now if i open Test.indt it opens as untitled.indd.  Is there a way to make it open as test.indd?
        • 1. Re: Indesign Template Question?
          Jump_Over Level 5
          If doc has a name --> means it was saved somewhere, right?
          Assuming you are openning a template by script - the name is known, right?
          Create a File with a desired filePath + name + .indd and save your doc to this file using
          aDoc.save(aFile) method.
          Jarek
          • 2. Re: Indesign Template Question?
            cbishop01 Level 2
            Right now if i save a file called File.indd  WHen i open it it says FIle.indd and if i Save File.indt it opens as untitled.indd
            What i'm trying to do is work from my templates.  So if i want to open the Indesign Template "Test.indt" by double clicking or file/open (Not by script) the file that opens is "untitled.indd.  I want it to retain the name of the Template and open as Test.indd . The indesign Templates are saved in a different place than the indd files.  I dont mind pointing the indd file to a certain location.  Because we work with so many files in different places i dont think the file path will be necessary.  I'm not wanting it to save when opened just retain the File name.
