2 Replies Latest reply on Jan 23, 2017 5:25 AM by Mohammad Modassir
    What is the script/code for this?
    Mohammad Modassir Level 1
      What is the FindChangeByList script or code for changing the style of Chapternames/headings using the font Times New Roman and font-size 14 pt and leading 10—from “Title Case” to “lowercase”?
        • 1. Re: What is the script/code for this?
          Jump_Over Level 5
          text.changecase() is a method not a preferences property --> so you need to set all desired format preferences
          alike:
          app.findTextPreferences.appliedParagraphStyle = ?
          app.findTextPreferences.appliedFont = ?
          app.findTextPreferences.pointSize = ?
          and loop into result of app.findText()
          Inside a loop you need to apply method changecase() to each found occurrences.
          Jarek
          • 2. Re: What is the script/code for this?
            I’m not familiar with that kind of scripting. Is there a way to do this by FindChangeByList.txt i.e using notepad.txt only?
            Like this example?
            grep {findWhat:"\\u+",appliedFont:"Arial",fontSize:"10.5"} {changeTo:"",appliedFont:"Calibri",fontSize:"12"} {includeFootnotes:true, includeMasterPages:true, includeHiddenLayers:true, wholeWord:false}
