7 Replies Latest reply on Jan 18, 2017 2:10 AM by davescm
    Selecting a translucent cloud
    rea5245
      I was hoping someone could offer advice advice on selecting the translucent parts of a cloud in a photo.
      I took this picture in the Valley of Fire near Las Vegas:
      I think this picture has potential. I like the clouds hovering above the mountain and the slight haziness of the mountain in the distance. My ideas are to increase the contrast in the clouds so that the sky has some texture, increase the saturation of the mountain and perhaps layer some more haze over it, and brighten the plant in the foreground. (I am uncertain of my aesthetic taste, so if you think I'm misguided, feel free to tell me. But that's not why I'm posting.)
      My first challenge, which I hope you can advise me on, is selecting the clouds. This might be a bit of a newbie question, but my difficulty is where the mountain is partially visible through the clouds. How can I select the cloud, select the whiteness of where the mountain shows through (i.e. I'll want to increase the contrast of the white cloud without increasing the contrast of the mountain that is partially visible through it), and avoid any sharp edges in the selection?
      Thank you,
        Bob
        • 1. Re: Selecting a translucent cloud
          Trevor.Dennis Adobe Community Professional
          Camera RAW > fx > DeHaze, is my first thought
          • 2. Re: Selecting a translucent cloud
            MatteoMasciotti Level 1
            Hello Bob,
            First of all, very lovely picture you have there!
            Now, Photoshop offers several ways to select the clouds in this picture, but my safe bet is to work with the "color range" in the "selection" application menù.
            When you work with this tool you can easily
            1) sample the color you want to select using the color sampler in the color range window
            2) decide to add more of a color using the eyedropper tool with the plus icon at the bottom (and simply drag over your clouds)
            3) confine the selection to only the portions of the image that you want to select by ticking the option "localized color cluster" and play with both the range slider (how far from the sampled point you want to expand) and the "fuziness" slider (how much of that color you want to include)
            As you can see from my first picture, you 'll get a nice selection that includes semitransparent areas of the clouds. Remember, white is what is selected, black is what is not-selected..everything in between =semi trasparent areas!
            If you want to further refine your selection, you can proceed to the "select and mask" area, either by using the following keyboard shortcut : CMD+ALT+R / CTRL+ALT+R , or, by going in the "SELECT" application menù and choose "select and mask". In this area you can cycle through many different view modes by pressing the "F" key. Pick the visualization you prefer and start refining the semi transparent areas of your clouds with the "refine edge brush tool". A few strokes on those areas and you will have a nice selection.refine edge.png
            • 3. Re: Selecting a translucent cloud
              davescm Adobe Community Professional
              Hi
              I would probably tackle that pic in camera raw with the Dehaze Filter pointed out by Trevor and local gradients and adjustments. ( I have not tried it here as the very low res pic you posted just brings out jpeg artifacts if you try and tackle the sky.
              To answer your original question - how to select the sky. For this pic I would do that pic with calculations. The principle is you use the image to mask itself.
              1. Go to the channels panel and select the blue channel
              2. Go to Image - Calculations and set it up to multiply the blue channel by itself and output  to a new channel
              This will add an Alpha channel
              3. Repeat the calculation this time on the new Alpha channel
              This will give you an new channel - Alpha 2
              4. With the Alpha 2 Channel selected - get a soft brush set to "Overlay " and opacity 50%
              Load it with White and paint on the white areas
              Load it with black and paint on the black
              Leave the soft borders alone
              Result is a nice black and white channel with a soft transition
              You can load it in as a selection by clicking in the channels panel and invert it if you want to mask the sky and treat the foreground
              I hope that helps
              Dave
              • 4. Re: Selecting a translucent cloud
                davescm wrote:
                Hi
                Dave
                LOL, I was eating my breakfast typing with one hand, or I'd have mentioned it should be done with the RAW file.  I was only able to nudge DeHaze a tiny bit with the supplied image, before it turned to (green) custard!
                I'd love to see a full size version of the image because it has such strong strata running through the mountain.  How about it Rea?  And also tell us were it was taken please?
                • 5. Re: Selecting a translucent cloud
                  rea5245 Level 1
                  It was taken in Valley of Fire near Las Vegas, NV. There's no RAW image - I was on a family vacation, traveling light, so I only had a point-and-shoot.You can see the full size image at IMG_2464 | Valley of Fire, NV | Bob Alexander | Flickr
                  I'm not sure I want to de-haze it. I was thinking of adding fog to make the mountain a little more mysterious (while also increasing its saturation). But as I said before, I don't have a lot of confidence in my aesthetic sense, so I might be wrong about that.
                  - Bob
                  • 6. Re: Selecting a translucent cloud
                    postrophe Level 4
                    Hi
                    You could use a fog brush to add some effects : Fog Free Brushes - (79 Free Downloads)  on a new layer.
                    Pierre
                    • 7. Re: Selecting a translucent cloud
                      Hi Bob
                      Thanks for posting the higher res pic.
                      There are no rights and wrongs when deciding which way to go. Once possible way is to use the Camera Raw Filter to bring out some of the detail.
                      I used a gradient set to a bluer colour temp on the sky which brought out some detail in the white area. Plus varying amounts of clarity and de-haze in local brushes on the mountain (and clarity set to a negative value in the sky to cover up any jpeg artifacts which appeared when bringing out some cloud detail).
                      Hope that helps give you some ideas
                      Dave
