1 Reply Latest reply on Jan 18, 2017 2:10 AM by Nanaky
    Check activation?
      When  I go to download a book i get an error message  "check activation"    Checking activation shows that the pc is authorized - however i have changed my email - would this be the problem.. and should I erase the activation and put in the new email.   I just want to read my books... no big deal...plain and simple request
      How to authorize my e-reader?
      Adobe Digital Editions
        • 1. Re: Check activation?
          Nanaky Level 5
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
