7 Replies Latest reply on Jan 19, 2017 3:08 AM by Obi-wan Kenobi
    creating object with properties
    foltman Level 1
      Hi guys!
      I'm trying to figure out how exactly creation properties work.
      Here is some rectangle:
      myFrame = app.activeDocument.pages[0].rectangles.add({
           geometricBounds: [0,0,100,100],
           fillColor: 'None',
           contentType: ContentType.GRAPHIC_TYPE
      I want to add frameFittingOptions to in while I'm creating whole object, so:
           contentType: ContentType.GRAPHIC_TYPE,
           frameFittingOptions.fittingOnEmptyFrame: EmptyFrameFittingOptions.FILL_PROPORTIONALLY
      And now I'm reciving error:
      Where is my mistake?
      Can I pass all properties during creating object?
      Thanks for any feedback,
      Jarek
        • 1. Re: creating object with properties
          Loic.Aigon Adobe Community Professional
          Hi
               fillColor: 'None',
               contentType: ContentType.GRAPHIC_TYPE ,
            frameFittingOptions: {fittingOnEmptyFrame: EmptyFrameFittingOptions.FILL_PROPORTIONALLY}
          • 2. Re: creating object with properties
            foltman Level 1
            Heh, it is now quite obvious! Thank you, Loic.Aigon.
            Now there is second part of my problem. Can I add any type of property corresponding to object type?
            For example I'm trying to add grep style to a paragraph style the same way I did with frameFittingOptions:
            myDoc = app.activeDocument;
            myStyle = myDoc.paragraphStyles.add({
                nestedGrepStyles: {
                    appliedCharacterStyle: myDoc.characterStyles.item('some style'),
                    grepExpression: 'some expression'
            And it doesn't work, style is being created, but without grep style.
            Jarek
            • 3. Re: creating object with properties
              Marc Autret Level 5
              Hi Jarek,
              Keep in mind that nestedGrepStyles (as well as paragraphStyles) refers to a collection, that is, a special member that requires the add() method to be fueled. So you need to load it separately:
              myStyle.nestedGrepStyles.add({
                  grepExpression: 'some expression',
              Marc
              2 people found this helpful
              • 4. Re: creating object with properties
                foltman Level 1
                Ok, Marc, I understand. Everything is clear now, I see the difference.
                Thank you!
                Jarek
                • 5. Re: creating object with properties
                  Obi-wan Kenobi Level 5
                  Hi all!
                  In a similar way, I've a problem to add an auto-resizing property when I create an object style!
                      try {
                          var myOStyle = app.activeDocument.objectStyles.item("mySel");
                          myOStyle.name;
                      }  catch (e) {
                              var myOStyle = app.activeDocument.objectStyles.add({name: "mySel", enableFill: false, enableStroke: false});
                      myFrame.textFramePreferences.autoSizingType = AutoSizingTypeEnum.HEIGHT_AND_WIDTH;
                      myFrame.textFramePreferences.useNoLineBreaksForAutoSizing = true;
                  Thanks in advance!
                  • 6. Re: creating object with properties
                    Kai Rübsamen Level 4
                    Why? I think, Loics example is pretty clear?!
                    var curDoc = app.activeDocument;
                    var oStye = (curDoc.objectStyles.itemByName("mySel").isValid) ? curDoc.objectStyles.itemByName("mySel") : curDoc.objectStyles.add({name: "mySel"});
                    oStye.properties = {
                      enableTextFrameAutoSizingOptions: true,
                      textFramePreferences: {
                        autoSizingType: AutoSizingTypeEnum.HEIGHT_AND_WIDTH,
                        autoSizingReferencePoint: AutoSizingReferenceEnum.TOP_CENTER_POINT,
                        useNoLineBreaksForAutoSizing: true
                    or
                    if  (! curDoc.objectStyles.itemByName("mySel").isValid) {
                      var oStyle = curDoc.objectStyles.add({
                    • 7. Re: creating object with properties
                      Thanks Kai! Clear now!
