I have noticed that if you have a mask layer it also sometimes effect the parent comp so you have to pre-comp again to avoid that.
Sometimes it works like this and sometimes not.
Any ideas why?
/ Mattias
mattias@gordon.se wrote
But I learned if you use the pin tools on a vector layer and have that in a comp and rasterize that comp it will not work.
Yup. That's likely the problem!
From this page of the AE help files:
Note: Don’t animate the position or scale of a continuously rasterized layer with layer transformations if you are also animating the layer with the Puppet tools. The render order for continuously rasterized layers—such as shape layers and text layers—is different from the render orde
Mattias, your description is a little hard to follow. Can you post some screenshots or a recording of this happening? When you say "a mask layer" do you mean a separate layer that you're using as a track matte, or do you mean when you mask an individual layer?
it's high time you learned what the "Move All Attributes" switch actually does when you precompose.
1. I have a comp where the the top layer works as a Alpha mask.
2. In that comp it looks great
3. In the parent comp the alpha is masking even if I dont want it.
4. This happens sometimes and I guess there is some setting I missed tio check....
I will check the "Move All Attributes" and see if I missed somethng.
/ Matitas
"Move All Attributes" applies only to pre-comping. How are you applying the matte to your other layers in the comp where the top layer is being used as your matte? Are you using the Set Matte effect and applying it to all layers, or do you only have two layers in this comp and you're using the top layer as a track matte?
Can you please post a screenshot of what it looks like in the comp with the matte and the parent comp? Make sure to toggle the transparency grid in the Comp panel so you can see what's actually being matted.
I tried to track it down but I need to look this through so I give you good info. I might also be a silly mistake. I get back. thanks for your help so far.
Hi Mattias Gordon,
What did you do to solve this issue? Do you still need help? Please let us know.
Kevin
I haven´t really tracked it down.
It will look weird or not show up.
I think it will have something with the rasterize effect on a comp with vector layer ( with an effect on it ) inside to do. this thing too maybe.
/ Matitas
Note: Don’t animate the position or scale of a continuously rasterized layer with layer transformations if you are also animating the layer with the Puppet tools. The render order for continuously rasterized layers—such as shape layers and text layers—is different from the render order for raster layers. You can precompose the shape layer and use the Puppet tools on the precomposition layer, or you can use the Puppet tools to transform the shapes within the layer.
(See Render order and collapsing transformations and Continuously rasterize a layer containing vector graphics.)
If you are using the Puppet Pin tool, I would highly recommend going through all of the resources on that page. It'll help you avoid gotchas like this.
