4 Replies Latest reply on Jan 19, 2017 12:03 PM by JimHess
    Lightroom and external drives
    daved37865138
      Basically, I have a couple of related questions.
      im now at a stage where I should be seriously looking at better backup.
      i run LR from a desktop pc, and also want to run it occasionally on a laptop offsite.
      my intention is to backup to a portable external drive ( and cloud). firstly, for the backup, should it be a mirror image of my internal drive, which is only has LR data on ( everything else is a separate SSD)?
      if this is the case, then can the external drive be the default drive for LR on the laptop?
      hope that makes sense.
      thanks
      Dave
        • 1. Re: Lightroom and external drives
          ManiacJoe Adobe Community Professional
          Regardless of what form your backups take, you need to make sure that you never use them for any other purpose than an emergency restore. Otherwise you risk losing these files just like you might lose the masters.
          The easiest (not prettiest) way to share your edits between multiple computers is to put the images and the catalog on an external drive and move the drive from computer to computer as needed. (This usually results in a need for two external drives: one to use and one as the backup.)
          As for the actual backup, keeping it as a simple mirror of the master folder tree is the easiest way to go. This can easily be done using drag and drop from Explorer/Finder, or a recursive copy command in a shell script.
          • 2. Re: Lightroom and external drives
            dj_paige Level 10
            Agreeing with ManiacJoe, this is a poor idea.
            You must make backups of your catalog file and presets and all photos to a different physical disk, and then NOT USE the backups for any purpose except an emergency where your originals are no longer available.
            • 3. Re: Lightroom and external drives
              daved37865138 Level 1
              Guys.
              You're right. I didn't think it through properly.
              Another question if i can? Is it possible to sync the laptop in the same way as Lightroom for Web or Mobile? I don't particularly need access to the entire catalog
              • 4. Re: Lightroom and external drives
                It is only possible to synchronize one catalog with Lightroom Mobile or Lightroom for the web. So if you are synchronizing from your main computer then you can go to Lightroom.adobe.com on your laptop and sign in with your Adobe ID and password. Then you will have access to all of the images that you have synchronized from your main computer. But you cannot synchronize from your laptop in addition.
