3 Replies Latest reply on Jan 19, 2017 10:37 PM by jessevic
    Popup window with checkbox written in Javascript
    jessevic
      Hello,
      Task of the checkboxes in the popup window is to write the checkbox values to File > Properties > Description > Title.
      If you selected 2 checkboxes, a ";" should be a separator between the 2 fields in the File > Properties > Description > Title field.
      If you select only 1 checkbox, there is NO ; at all.
      If you select 3 checkboxes, the separator is always a ; (in this case 2 times a ; )
      This is one of my tries, hope that some freaks can help me.
      I need also to exand the checkboxes until 9 different checkboxes.
      var dialog2 =
              initialize: function(dialog) {
                  // Set a default value for radio button field
                  dialog.load({"ckb1": true });
              commit: function(dialog) {
                  // When the user presses "Ok", this handler will execute first
                  var results = dialog.store();
              // The dialog box description
              description:
                  name: "More Personal Information",
                  elements:
                          type: "view",
                          align_children: "align_left",
                          elements:
                                  type: "static_text",
                                  name: "Personal Information",
                                  bold: true,
                                  font: "dialog",
                                  char_width: 30,
                                  height: 20
                                  type: "check_box",
                                  item_id: "ckb1",
                                  type: "check_box",
                                  item_id: "ckb2",
                                  name: "Pet Owner test"
                                  type: "check_box",
                                  item_id: "ckb3",
                          type: "gap",    //Add a small vertical gap between
                          height: 10      //check boxes and buttons
                          type: "ok_cancel",
                          ok_name: "Ok",
                          cancel_name: "Cancel"
      this.info.author=""
      if ("ok"==app.execDialog(dialog2)){
          this.info.title=dialog2.results
      Examples
      checkbox 1 and 2 selected results in: Pet Owner;Pet Owner test
      checkbox 1 selected results in: Pet Owner
      checkbox 1 and 2 and 3 selected results in: Pet Owner;Pet Owner test;Pet Owner test
      No checkbox selected results in: <<empty field>>
