2 Replies Latest reply on Feb 11, 2017 1:31 PM by gkaiseril
    Adobe Acrobat Pro 7 - Fillable Forms - Java Script for List Options.
    emilieb70488021
      Example:
      1. Please Select each applicable option:
      Option 1
      Option 2
      Option 3
      Option 4
      Option 5
      Option 6
      2 By holding the CTL key the user selects:
      Option 1
      Option 2
      Option 3
      Option 4
      Option 5
      Option 6
      Printed/Saved output appears as:
      Option 2, Option 4, Option 5.
      Can anyone give me the Adobe Javascript to make this happen?
      Thanks in advance!!!!
      [Moved from the non-specific Coding Corner to a product-specific forum - moderator]
        • 1. Re: Adobe Acrobat Pro 7 - Fillable Forms - Java Script for List Options.
          Acrobat-specific JavaScript questions should be asked here: JavaScript
          • 2. Re: Adobe Acrobat Pro 7 - Fillable Forms - Java Script for List Options.
            Have you looked at the freely available Acrobat JavaScript Reference?
            A combo box can be set to allow multiple or a single selection. One then needs to test the value of the field to see if it is an array or a single item. You can test the type of the value of the combo box to see if it is "string" for a single answer or "object" for multiple selections in an array;
            Assuming a combo box field with a name of "Combo Box1" and text field for the result with a name of "Text1", a possible custom calculation script could be:
            event.value = "";
            // get combo box field object;
            var oCombo = this.getField("List Box1");
            // test value of combo box;
            if(typeof oCombo.value  == "object")
            var aValues = new Array();
            for(var i = 0; i < oCombo.value.length; i++)
              if(oCombo.value[i] != " " || oCombo.value[i] != "")
               // eliminate single space or null string selections;
               aValues[aValues.length] = oCombo.value[i];
            event.value = aValues.join(",");
            } else {
            if(oCombo.value != " " || oCombo.value != "")
              // eliminate space or null sting seledtions;
              event.value = oCombo.value;
