This is a sample logo I have, let assume I created it in Indesign, and I don’t have the original file any longer. How do I change the color of letter “b” and the letter “g” to white?
Thanks for help
Kind, Modassir
Please help me understand - if the logo was created in InDesign, but you no longer have the original file, what format is the logo currently saved in?
Forget the above, please focus on this sample:
Now, if I want to put this on a book-cover, I go to color, and swatches and change to “paper”-option, and then I choose the color of background to blue, but still what is inside the letter Q in the above logo, does not change to blue color i.e the background color.
I want what is inside the letter Q in the above logo, to have blue background while at the same keeping the black lines, and the letter Q, make it to white color. How can I do that if the logo-format is .indd?
Change the Blending Mode to Multiply in the Effects panel.
Ok, that worked, but the letter Q and the black lines inside it are still in black color, how do I change the letter Q and the lines inside to white color?
Select it and change what's black to white.
If it turns out it was made in Illustrator, do it in Illustrator. If it was made in Photoshop, do it in Photoshop.
i don’t have the origin file. So the logo is in .png format as a picture. How can I change?
It's a raster image, so you'd have to edit it in an image editor; i.e., Photoshop.
Export to PDF with no downsampling, Open the PDF in Photoshop or other raster image editor of your choosing.
Of course, the correct way to go about it would be to obtain a vector-based copy from the original designer or owner.
All of these suggestions are correct and hopefully helping you, but they're all band-aids. Your trying to hack your way through making this thing work. If it's a .png file, it's almost guaranteed to be low quality when printed on the book cover. I'd place this graphic in Illustrator and run Image Trace on it to vectorize the logo. It won't be perfect but it won't be any worse than the .png file and you'll be able to manipulate the graphic.
Also this logo would be quite simple to recreate from scratch.
