7 Replies Latest reply on Jan 24, 2017 12:46 AM by BenPleysier
    Windows 7 + Dreanweaver CC 環境で Compass のエラー
    剛臣西55544709 Level 1
      Windows 7 + Dreanweaver CC (2017.0.1 9346 ビルド) 環境で Compass を使用する際、.sass で @import "compass"; を記述するとインポートできずにエラーになります。
      @import "compass/reset"; は OK です。
      以下はエラーメッセージ。
      Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/(my home)/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41567cc2a7d8 997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/gener al/_hacks.scssc20170120-5944-aqqlcs
      Macos Sierra +  Dreanweaver CC 環境では、上記エラーは発生していないので、 Windows 7 環境での問題と考えています。
      何か解決策をありますか?
        • 1. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
          Preran Adobe Employee
          Not the exact answer to your question, but I want to make sure that you are following the procedure mentioned in this document.
          See, "Using the compass framework" in Using CSS preprocessors in Dreamweaver
          Preran
          • 2. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
            剛臣西55544709 Level 1
            I have read "Using CSS preprocessors in Dreamweaver". So, I have tried to make my new test site with the instructions in it. But, just found the same error.
            See config.rb, screen.scss, screen.css:
            Takeomi
            -- config.rb
            require 'compass/import-once/activate'
            # Require any additional compass plugins here.
            # Set this to the root of your project when deployed:
            http_path = "/"
            css_dir = "stylesheets"
            sass_dir = "sass"
            images_dir = "images"
            javascripts_dir = "javascripts"
            # You can select your preferred output style here (can be overridden via the command line):
            # output_style = :expanded or :nested or :compact or :compressed
            # To enable relative paths to assets via compass helper functions. Uncomment:
            # relative_assets = true
            # To disable debugging comments that display the original location of your selectors. Uncomment:
            # line_comments = false
            # If you prefer the indented syntax, you might want to regenerate this
            # project again passing --syntax sass, or you can uncomment this:
            # preferred_syntax = :sass
            # and then run:
            # sass-convert -R --from scss --to sass sass scss && rm -rf sass && mv scss sass
            -- sass/screen.scss
            @import "compass";
            body {
              background-color: #fff;
            -- stylesheets/creen.css
            Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41 567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/gener al/_hacks.scssc20170123-12964-b3ufpm
            Backtrace:
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `initialize'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `open'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:136:in `block in initialize'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tmpdir.rb:129:in `create'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/2.2.0/tempfile.rb:133:in `initialize'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `new'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/util.rb:1225:in `atomic_create_and_write_file'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/filesystem.rb:39:in `_store'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/base.rb:51:in `store'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `block in store'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `each'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/cache_stores/chain.rb:19:in `store'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:414:in `_to_tree'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:309:in `to_tree'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:324:in `block in visit_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `block in with_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:115:in `with_frame'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:88:in `with_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:323:in `visit_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `block in visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `block in with_base'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/stack.rb:79:in `with_base'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:158:in `visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block (2 levels) in visit_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `map'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:326:in `block in visit_import'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `block in visit_children'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `map'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:52:in `visit_children'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:167:in `block in visit_children'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:179:in `with_environment'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:166:in `visit_children'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/base.rb:36:in `block in visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:186:in `visit_root'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:157:in `visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/visitors/perform.rb:8:in `visit'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:36:in `css_tree'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/tree/root_node.rb:20:in `render'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/engine.rb:278:in `render'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engi ne.rb:17:in `block in render'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engi ne.rb:29:in `with_import_scope'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-import-once-1.0.5/lib/compass/import-once/engi ne.rb:16:in `render'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:492:in `update_stylesheet'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:215:in `block in update_stylesheets'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `each'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/sass-3.4.20/lib/sass/plugin/compiler.rb:209:in `update_stylesheets'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/sass_compiler.rb:40:in `compile!'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/update_project.rb:4 9:in `perform'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/base.rb:18:in `execute'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/commands/project_base.rb:19: in `execute'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:43:in `perform!'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/lib/compass/exec/sub_command_ui.rb:15:in `run!'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:30:in `block in <top (required)>'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `call'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-1.0.3/bin/compass:44:in `<top (required)>'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `load'
            C:/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/bin/compass:23:in `<main>'
            body:before {
              white-space: pre;
              font-family: monospace;
              content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41 567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/gener al/_hacks.scssc20170123-12964-b3ufpm"; }
            • 3. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
              BenPleysier Adobe Community Professional & MVP
              Please show us the contents of config.rb
              Is config.rb located in the root directory of your site?
              Is the location of config.rb specified in Site Setup?
              Perhaps I should have asked the most important question first, namely do need Compass or can you do without. See here for more info Why I Don't Use Compass Anymore
              If you do not need Compass, then the problem is solved.
              Edit:
              I do use Compass only to create my image sprites and have no problem with it. However, I will be moving away from that soon preferring to use SVG's equivalent. After that, I will have no use for Compass.
              • 4. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
                剛臣西55544709 Level 1
                Here:
                -- config.rb
                http_path = "/"
                sass_dir = "sass"
                # and then run:
                Yes.
                Yes.
                > Edit:
                Yes, I need Compass for now.
                I have read your "info Why I Don't Use Compass Anymore". I partially agree.
                I'm using Compss on Windws 7 + Cygwin + cygwin ruby gem + Compass with many Compass mixin. It's not bad. But, my Web team members are not familiar with Cygwin, ruby, gem. So, I'm going to change our development environment from Cygwin + Compass to DW + Compass. I's more simpe for my Web team members.
                Takeomi
                • 5. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
                  Change
                  http_path = "/"
                  sass_dir = "sass"
                  to (note the http_path link which goes below the root directory)
                  http_path = "../"
                  sass_dir = "sass"
                  • 6. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
                    剛臣西55544709 Level 1
                    I have chaged config.rb. But, nothing has been changed.
                    Thannks,
                    Takeomi
                    --- config.rb
                    http_path = "../"
                    sass_dir = "sass"
                    # and then run:
                    --- sass/screen.scss
                    @import "compass";
                    body {
                    --- stylesheets/screen.compass - compiled sass/screen.scss
                    Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41 567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/gener al/_hacks.scssc20170124-16324-lpmam3
                    Backtrace:
                    body:before {
                      white-space: pre;
                      content: "Errno::ENOENT: No such file or directory @ rb_sysopen - C:/Users/merita/Documents/Project/test-dw-compass/.sass-cache/75fcaf1b4852ceb732871195e41 567cc2a7d8997/C%058/Program Files/Adobe/Adobe Dreamweaver CC 2017/ruby/lib/ruby/gems/2.2.0/gems/compass-core-1.0.3/stylesheets/compass/utilities/gener al/_hacks.scssc20170124-16324-lpmam3"; }
                    • 7. Re: Windows 7 + Dreanweaver CC 環境で Compass のエラー
                      I'm sorry that it still will not work. Please have a look at how I have my setup.
                      1. Directory structure
                      2. Site Setup - General
                      3. Site Setup - Source & Output
                      4. Site Setup - Compass
                      That's all and it works like a charm.
                      If, after comparing the above with your setup, you still cannot get it to work, you may like to try to un-install Dreamweaver, Use the Creative Cloud Cleaner Tool to solve installation problems and re-install Dreamweaver. Hopefully that will fix it. Fingers crossed.
