3 Replies Latest reply on Jan 23, 2017 8:23 AM by Szalam
    Settings for best render performance
    Mattandhisid
      First I'd like to say hello to everyone
      I have a question about AE settings for my Notebook to achieve best render and editing performance.
      My hardware:
      MSI PE70 2QE notebook
      i7-5700HQ
      16GB RAM
      1TB 7200 RPM HDD
      250GB SSD M.2 Samsung 850 EVO
      NVIDIA GTX960M
      & Windows 8.1 operating system
      Actually thing is which drive should be used for operating system, adobe ae app, project files, render file, and cache.
      I have no space for another hard drive so I have to be satisfied with what I have. Later on I'd like to add more memory.
      For now I have OS and APP on HDD and Cache set for SSD.
      I will be grateful for any suggestions
        • 1. Re: Settings for best render performance
          Dave LaRonde Level 6
          You've done just about everything you can on that thing.  Keep your cache cleaned out.
          "Yeah, but After Effects still runs slow!  Anything else I can do?"
          Sure -- get some AE experience under your belt.  It's not an editing application like PP,  it doesn't work like like an editing application and it's A LOT more complicated than an editing application.  Quirkier, too.  It probably would do you a lot of good to get your basic AE Training from the pros, which is something everyone should do:
          After Effects tutorials
          • 2. Re: Settings for best render performance
            Mattandhisid Level 1
            Thank You Dave .
            Actually I'm using AE for one thing.. exporting simple 60 second animations ( quicktime, animation, rgb + alpha, quality 100%)
            It's always some shape + text animation. Nothing else. Problem is that's it's always like 50 files per day and it takes long.
            It's only one reason and action I'd like to speed up.
            • 3. Re: Settings for best render performance
              If you're using a recent version of AE I'd recommend installing CC 2014. (How to install older versions here.)
              Work in your newer version and then open the file in CC 2014 and render with multiprocessing turned on. See if that renders more quickly.
              If you are using any flavor of CC 2015 or CC 2015.3, you won't have to do anything special to open those files in CC 2014. If you are using CC 2017 or CC 2017.1, you will need to Save As to go back a version.
