5 Replies Latest reply on Oct 15, 2008 11:24 PM by fober1
    checkbox hell
    radico
      I'm lost on this as everything I've found says to simply use cfparam but this doesn't seem to work for me. Running this on IIS and Coldfusion 7.
        • 1. Re: checkbox hell
          Level 7
          Do you want to elaborate on "doesn't work for you"?
          Adam
          • 2. Re: checkbox hell
            BKBK Adobe Community Professional & MVP
            Using the associative array notation for the form struct enables you to do away with the evaluate() function. Here are four suggestions:
            bgcolor="##006699"
            <cfparam name="#form[g & "mark"]#" default="0" type="Boolean">
            <cfif form[g & 'mark'] neq 0>
            #form[g & 'mark']#, #form[g & 'sfiid']#, #form[g & 'name']#, #form[g & 'package']#, #form[g & 'total']#, #form[g & 'hashinfo']#<br>
            • 3. Re: checkbox hell
              -==cfSearching==- Level 4
              radico wrote:
              > I'm lost on this as everything I've found says to simply use cfparam but this doesn't seem to work for me...
              > <input type="checkbox" name="#count#mark" value="1" checked visible="Yes" enabled="Yes">
              > <cfparam name="#Evaluate("form.#g#mark")#" default="0" type="Boolean">
              Evaluate() is causing the very error you are trying to prevent. The evaluate() function will execute before the cfparam code. So the form field still does not exist yet, which causes an error.
              Not that you need to use evaluate anyway. Just use the string name:
              <cfparam name="form.#g#mark" default="0" ...>
              > #evaluate('form.#g#mark')#,#evaluate('form.#g#sfiid')#,#evaluate('form.#g#name')#,>....
              To extract the values of dynamic form fields use array notation, instead of evaluate()
              #form[g &"mark"]#
              #form[g &"sfiid"]#
              • 4. Re: checkbox hell
                Radico,
                -==cfSearching==- opens up a question. Your original code suggests that the cfparam's name attribute is #form[g&'mark']#, the value of the form field. He suggests the name of the form field, form.#g#mark, which is the one I would also expect. You have to make a choice.
                • 5. Re: checkbox hell
                  fober1 Level 1
                  I have attached a set of functions that I use to
                  - Dynamically create these fieldnames
                  - Read the value from these dynamic fieldnames
                  - Read and format these values for DB use
                  I have updated your example, but since I don't have the tables setup I cannot verify if the updated script even works.
                  Hope that helps
                  cheers,
                  fober
                  <cfparam name="ID_ROW" default="0">
                  <cfif isdefined("btn_send")>
                  <cfloop index="ID_ROW" from="1" to="#form.count#" step="1">
                  <cfquery datasource="veryvip">
                  INSERT INTO itransact{
                  sfiid,
                  name,
                  package,
                  total,
                  hashinfo}
                  VALUES(
                  #dbvalue('sfiid','number')#,
                  #dbvalue('name','string')#,
                  #dbvalue('package','number')#,
                  #dbvalue('total','number')#,
                  #dbvalue('hashinfo','string')#)
                  </cfquery>
                  </cfloop>
                  <cfabort>
                  </cfif>
                  <cfquery datasource="veryvip" name="prepare">
                  select c.*, i.*
                  from itransact i, customers c
                  where i.sfiid=c.sfiid
                  </cfquery>
                  <cfform action="index.cfm" method="POST">
                  <table cellpadding="1" cellspacing="0" border="1" bordercolor="#006699">
                  <cfoutput query="prepare">
                  <cfset ID_ROW= ID_ROW +1>
                  <tr>
                  <td align="center">
                  <input type="checkbox" name="#fieldname(mark)#" value="1" checked visible="Yes" enabled="Yes">
                  </td>
                  <td><cfinput type="Text" name="#fieldname('sfiid')#" value="#sfiid#" required="Yes" visible="Yes" enabled="Yes" size="5"></td>
                  <td><cfinput type="Text" name="#fieldname('name')#" value="#firstname# #lastname#" required="No" visible="Yes" enabled="Yes"></td>
                  <td><cfinput type="Text" name="#fieldname('package')#" value="#package#" validateat="onBlur" validate="integer" required="Yes" visible="Yes" enabled="Yes" size="1"></td>
                  <td><cfinput type="Text" name="#fieldname('total')#" value="#dollarformat(total)#" required="Yes" visible="Yes" enabled="Yes" size="3"></td>
                  <td><cfinput type="Text" name="#fieldname('hashinfo')#" value="#hash(sfiid)#:#package#" required="Yes" visible="Yes" enabled="Yes" size="40"></td>
                  </tr>
                  </cfoutput>
                  <tr>
                  <td> </td>
                  <td align="center">
                  <cfinput type="Hidden" name="count" value="#ID_ROW#">
                  <input type="submit" name="btn_send" value="Send">
                  </td>
                  <td colspan="4"> </td>
                  </tr>
                  </table>
                  </cfform>
                  <cffunction name="fieldname" output="No">
                  <cfargument name="field" type="string" default="">
                  <cfparam name="id_area" default="">
                  <cfparam name="id_row" default="">
                  <cfif id_row NEQ "">
                  <cfset local.field= "#id_row#_#field#">
                  <cfelse>
                  <cfset local.field= "#field#">
                  </cfif>
                  <cfif id_area NEQ "">
                  <cfset local.field= "#id_area#_#local.field#">
                  <cfelseif id_form NEQ "">
                  <cfset local.field= "#id_form#_#local.field#">
                  </cfif>
                  <cfreturn local.field>
                  </cffunction>
                  <cffunction name="fieldvalue" output="No">
                  <cfset local.temp_field= im_fieldname(field)>
                  <cfif isdefined("#local.temp_field#") IS TRUE>
                  <cfset local.temp_value= evaluate("#local.temp_field#")>
                  <cfelse>
                  <cfset local.temp_value= "">
                  </cfif>
                  <cfreturn local.temp_value>
                  </cffunction>
                  <cffunction name="dbvalue" output="No">
                  <cfargument name="type" type="string" default="string">
                  <cfswitch expression="#type#">
                  <cfcase value="string">
                  <cfreturn "'#fieldvalue(field)#'">
                  </cfcase>
                  <cfcase value="number">
                  </cfcase>
                  <cfcase value="date">
                  <cfreturn "'#CreateODBCDate(fieldvalue(field))#'">
                  </cfcase>
                  </cfswitch>
                  <cfelse>
                  </cfif>
                  </cffunction>
