1 Reply Latest reply on Mar 24, 2017 2:13 PM by Akki_24
    how to change the text direction
    orir8535087
      Hey everyone,
      i'm new to Acrobat DC, I use Windows 10 and the language is Hebrew,
      I downloaded the Acrobat DC and type in english and everything is backwards (for example the dot in the end of the sentance is not staying there - .example)
      I went into preferences-language- and choose english and left to right direction, nothing helped,
      can someone please help and guide me with that?
      thank!!
      ori
        • 1. Re: how to change the text direction
          Akki_24 Adobe Employee
          Hi Orir8535087,
          We apologize for the delay in response to your query.
          As mentioned above, you are working on Windows 10 computer and its language is Hebrew.
          I assume, that the application language (Acrobat DC) should also be same as default language of system or have you installed it in English?
          If shared, if you have already changed the Language setting under preferences and it is still not in correct format then it could be a document specific problem.
          You must check with other file whether its causing the same problem or not?
          Regards,
          Akanchha
