13 Replies Latest reply on Feb 6, 2017 2:32 PM by Kevin-Monahan
    3D camera tracker problem
    hussein1313 Level 1
      Hello guys!
      I used 3D camera tracker but I don't know why in a part of the video the points suddenly moves. Please check the link below, I provided a screen record.
      screen - YouTube
      P.S: I used "Tripod pan" in "Solve Method" setting.
      Regards
        • 1. Re: 3D camera tracker problem
          What, exact, version number of AE are you using (down to the last decimal point)?
          What format and codec is that source footage?
          • 2. Re: 3D camera tracker problem
            hussein1313 Level 1
            I use After effects CS6, version 11.0.4.2
            Video details:
            .MOV
            Video codec: h264
            Video BitRate: 9959
            Video FrameRate: 25
            • 3. Re: 3D camera tracker problem
              Roei Tzoref Adobe Community Professional
              in addition to what Szalam mentioned, here are my pointers:
              I see you already made some compositing and what not. start fresh and:
              1. make sure your composition and source footage frame rates match
              2. select the start and end points of your footage layer in time you wish to track and trim it accordingly
              3. apply the 3D Camera tracker. this looks like a Tripod pan but let Ae try for itself. you can always change it.
              4. check your average error and see if it's below 1 pixel.
              if this does not work, come back with the results. if you can, upload the footage so we can try for ourselves and maybe guide you through the process.
              • 4. Re: 3D camera tracker problem
                hussein1313 Level 1
                Thanks Roei for your reply.
                1. composition and footage frame rate is same, 25.
                2. I did this but I faced to this problem.
                3. AE couldn't solve camera in other options and just in Tripod pan it worked and that's why I chose this one.
                4. Average error is 6.09
                Here you can download the project file, NOT footage because I have some mask layers and maybe it helps better.
                final-02.aep.zip - Google Drive
                Here is the footage also if it helps:
                footage (1).mp4 - Google Drive
                Thank you
                • 5. Re: 3D camera tracker problem
                  Use Adobe Media Encoder to transcode that footage into a proper production codec. H.264 in the MOV wrapper is pretty buggy and has never been supported by Apple.
                  By production codec, I mean something like QuickTime with the Photo-JPEG codec or QuickTime with the PNG codec.
                  Then try tracking that new video file instead.
                  • 6. Re: 3D camera tracker problem
                    How much of that shot exactly are you trying to track?
                    You should trim the shot to the exact frames that are going to be used in the final composite.
                    If your 3-D object is going to approach the edge of the frame then you must remove the lens distortion before you do the 3-D tracking. If you do not already have a lens profile then you will need to make one up or do some experimentation. There is an awful lot of lens distortion in your shot, maybe as much as 20%.
                    The footage has also been cropped. You should be using the original full frame footage for tracking because you will end up with a much better solution.
                    If you get into this kind of situation again and have any control over the shooting make sure they shoot a grid with the camera and lens they are going to use in the production so you can accurately calculate and correct lens distortion to do your compositing. Wide angle lensa distort at the edges but the AE camera or the stock camera in any 3-D app has a perfect lens so you have to remove the distortion before the **** will accurately track all the way to the edge of the frame.
                    • 7. Re: 3D camera tracker problem
                      probably the result of not enough information for you to track.
                      I see your footage - I marked in red the parts in question.
                      a few questions:
                      1. why is your source footage cropped significantly? why there is some compositing element in front of everything - what is it? was it shot live in the actual shot? don't you have the original raw footage? no cropping, no compositing, no color correction.
                      2. what do you want to achieve visually? do you really need the whole pan? you should trim the footage to just the parts that need to be tracked before you track them.
                      • 8. Re: 3D camera tracker problem
                        hussein1313 Level 1
                        I need 12 second of a 12 minute short movie. This footage is the footage I've received and I didn't touch the format, also I didn't crop that. The thing I that I want to try is to add some objects in jpg format outside of the car.
                        • 9. Re: 3D camera tracker problem
                          You might be able to just use the regular point tracker for that or Mocha.
                          • 10. Re: 3D camera tracker problem
                            As I said before, if you want to insert some objects outside the windows of those objects approach the edge of the frame you're going to have to remove the lens distortion because things will not line up.
                            I would trim your footage to just the frames where you want to add the objects, then trim the composition height and width so you do not have any black bars,  then apply lens correction to try and remove the distortion at the edges, then pre-compose moving all attributes, then camera track the pre-comp and insert your 3-D layers.
                            The only other option is to stabilize the footage so things don't move and do the composite entirely in 2D, and then put the motion back in everything. Neither one of these is going to be easy or automatic.
                            • 11. Re: 3D camera tracker problem
                              And, again, do all of that AFTER you convert it to a proper production codec first to get rid of the weird H.264-ness.
                              • 12. Re: 3D camera tracker problem
                                good pointers from Szalam and Rick
                                if that's what you got then you can make do.
                                it all depends what exactly do you want to composite and where? 2D tracking can go a long way, especially with Mocha. show us what you intend to plant in there and where. also specify the timecode start and end based on the 20 seconds footage you provided.
                                • 13. Re: 3D camera tracker problem
                                  Kevin-Monahan Adobe Employee
                                  Hi Hussein,
                                  Sorry for your struggles with camera tracking. Some great advice here. Did any of these posts help solve your issue? Please let us know, as these kind gentlemen did volunteer to help you. If you do need additional help, please let us know that, as well.
                                  Thanks!
                                  Kevin
