• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Clipping Path for Object Drawn With InDesign
Participant ,
Jan 20, 2017 Jan 20, 2017
I created these two bookshelves using the rectangle tool in InDesign, I like how they turned out, but there is one problem. They have no clipping path options. I need InDesign to set/ activate/ recognize... whatever... a clipping path for this whole shape so that I can set a text wrap around it, and create a cast shadow for it, but I don't know how to get it to show up.
As you can see above, all of the clipping path options are grayed out. This is preventing me from being able to apply a text wrap to the shape rather than its bounding box, or creating a cast shadow. Sorry for the extra screen, I couldn't get a picture of the menu with just one screen because alt closes the menu lol. So how to I create or get InDesign to recognize a clipping path for this object?
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Mentor , Jan 20, 2017 Jan 20, 2017
While everything above, what Barb said, is absolutely true...
Make copies of both shelves. Combine each shelf to a single object.
Select both, combine.
If needed, patch the „holes”: put any figure(s) on top
Select all and Combine again:
Barb, I waited for You patiently this time - You're the first
Votes
Translate
Translate
Community Expert ,
First of all, impressive use of the rectangle tool in InDesign!
Now, I think there is confusion on needing a clipping path. In InDesign, the Clipping Path dialog box is used for transparency. In text wrap, the clipping path option is used to access a clipping path coming from Photoshop as a way of handling text wrap. Same name, two very different applications.
To apply text wrap to a bounding box, you know to choose button #2.
To apply text wrap to the object shape, choose button #3. It will follow your shape automatically.
If you want to further tweak the wrap, use the Pen tool and Direction Selection tool and for instructions see "Change the shape of a text wrap":
Learn how to wrap text around objects in InDesign
Votes
Translate
Translate
Report
Report
Participant ,
Thank you! Although I had already tried "wrap around shape" and was not getting the effect that I wanted. Because this large shape is made up of a lot of grouped smaller shapes, even the "wrap around shape" option does not wrap the text around each edge of the shape, instead, it wraps around the rectangle created around the whole when you group them all together. I should have used the "combine shapes" option in pathfinder rather than grouping, as Winterm suggested, that would have avoided this whole issue. However, I was able to achieve close enough to what I wanted by ungrouping 1 level (so that the single shape is now 3, both sets of shelves and the oval rug) and text wrapping each individually (which wraps around the curve of the oval because it is only one shape and not a group, and wraps the smaller rectangle around each shelf rather than the larger rectangle around all 3 shapes) then re-grouping the 3 back together. This way I didn't have to ungroup everything and tediously combine each shape. The cast shadow isn't important enough to go through all that lol.
Votes
Translate
Translate
Report
Report
Community Expert ,
Did you see the link I added at the very bottom? Using the Pen tool and Direct Selection tool you can make a custom text wrap do anything you want! IMHO, that was the quickest possible way to get where you wanted to go.
Votes
Translate
Translate
Report
Report
Participant ,
No I had not seen that, thank you!
Votes
Translate
Translate
Report
Report
Guest
Apr 26, 2017 Apr 26, 2017
LATEST
your information is correct
Votes
Translate
Translate
Report
Report
Mentor ,
Votes
Translate
Translate
Report
Report
Community Expert ,
LOL
Votes
Translate
Translate
Report
Report
Participant ,
That is most definitely what I should have done to begin with. I will remember this in the future. I am not very experienced in InDesign and have largely taught myself, so a lot of the things I do are the hard way or don't make sense. Like grouping shapes instead of combining them. Good tools for the future, thank you!
Votes
Translate
Translate
Report
Report
Mentor ,
Glad you're ready to go further
Grouping not always "doesn't make sense". Say, you can "ungroup" at any time, but you can't un-combine (only undo), so be sure you're working on a duplicate!
Also resulting figure gets attributes of the frontmost object, all others are gone. Combine won't work on grouped objects, too, so you must ungroup them first.
Another thing, often all those steps I showed can be skipped - if you need only the final result - just ungroup everything, patch holes (or leave it), select all, combine. Especially when the figures are simple.
And the last: there's even the script which does this job, but no need to bother for the one-time thing, I guess.
Votes
Translate
Translate
Report
Report
Community Expert ,
You don't need a clipping path for vector objects only. Makes no sense.
Votes
Translate
Translate
Report
Report
Participant ,
The point is that the text wrap options were not allowing me to tell it to detect the edges and wrap around the edges of the shape because it was a group of shapes instead of being combined into one single shape. I also had wanted to create a cast shadow for each shelf. The only way i know how to do that is by using a shapes clipping path to create an overlay shape with a black to white gradient. I am probably not asking correctly thought because I am very very new to InDesign. Thank you for your help all!
Votes
Translate
Translate
Report
Report
