• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
15
Error: Can't move the objects. The requested transformation would make some objects fall completely off the drawing area.
New Here ,
Jan 20, 2017 Jan 20, 2017
I just updated to illustrator 2017, and now I'm having problems.
1. Drew line illustration with pen tool. Select All. Hit upward arrow. Get error message that says: "Can't move the objects. The requested transformation would make some objects fall completely off the drawing area."
2. Select All.. zoom all the way out to check the whole gray area for stray anchor points. Nothing showing.
3. Forum says to Clear Guides. I check and Clear Guides is grayed out.
4. I check to make sure no anchor points are on the edge of the artboard, though I can't imagine that would cause an issue. I move all anchor points inward. Still get error.
5. Select All and try to paste on new artboard in new window. Still get same error.
TOPICS
Performance
Views
108.2K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 21, 2017 Jan 21, 2017
Hmm, that's strange. Although you tested there ar no points on the edge of the document, can you try this?
1) Go to Select > Object > Stray Points (Illustrator now selects every 'loose/stray' anchor point).
2) Just hit Delete after that (to delete the open, loose points).
Maybe that would be the problem?
Votes
Translate
Translate
Adobe
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Mar 04, 2018 Mar 04, 2018
This worked for me.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 27, 2018 Apr 27, 2018
That worked for me... thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 07, 2020 Jan 07, 2020
Thank you
Votes
Translate
Translate
Report
Report
Community Beginner ,
Jan 25, 2020 Jan 25, 2020
Thank you so much!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 01, 2020 Mar 01, 2020
Thank you. I would never have figured this out on my own. Trying to get a proof out to a client and all of a sudden I couldn't move anything but laterally.  Thank you again!
Votes
Translate
Translate
Report
Report
New Here ,
Apr 01, 2020 Apr 01, 2020
It worked for me. Thanks you.
Votes
Translate
Translate
Report
Report
New Here ,
Dec 03, 2020 Dec 03, 2020
Worked for me! Thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Worked for me as well. Thanks, Rob!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 23, 2021 Mar 23, 2021
awsome dude, if stil not worked with this step try to clear guides, sometime guides are invisible
Votes
Translate
Translate
Report
Report
New Here ,
Mar 24, 2021 Mar 24, 2021
Thanks alot.
Wouldnt have never found the problem
Votes
Translate
Translate
Report
Report
New Here ,
Jul 13, 2021 Jul 13, 2021
This worked for me, thank you!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 28, 2022 Mar 28, 2022
Works in an instance, Kudos!
Votes
Translate
Translate
Report
Report
Sep 22, 2022 Sep 22, 2022
Thank you.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 21, 2022 Nov 21, 2022
Thank you. It works
Votes
Translate
Translate
Report
Report
New Here ,
Dec 16, 2022 Dec 16, 2022
Thank you, Rob!!!  I could NOT figure this out and this little tip did the trick!
Votes
Translate
Translate
Report
Report
New Here ,
Jan 18, 2023 Jan 18, 2023
Genius! Thanks so much!!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 23, 2023 Mar 23, 2023
that worked!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 11, 2023 Sep 11, 2023
Thanks a lot .
Votes
Translate
Translate
Report
Report
New Here ,
Mar 26, 2024 Mar 26, 2024
That worked! Thank you 🙂
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 19, 2024 Apr 19, 2024
This does not solve the problem of why sometimes items cannot reside outside the pasteboard, because sometimes they can. It's a mystery that cannot be solved
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello @Darth Vader,
Sorry to hear about your experience. Would you mind sharing some more details, like the exact version of the OS/Illustrator, exact details of your workflow, and a screen recording of the problem (https://adobe.ly/49ONEl8), so we can investigate this further?
Looking forward to hearing from you.
Anubhav
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 22, 2024 Apr 22, 2024
Here is a perfect example, on the right side, you can see that the artwork is happily residing outside of the pasteboard, but when I try to drag a copy outside of the paseboard on the left side, it fails & gives me the error message
Votes
Translate
Translate
Report
Report
Explorer ,
CC 27.4.1
OS X 14.4.1
Votes
Translate
Translate
Report
Report
