• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop CC 2017 is super slow + resets preferences everytime
New Here ,
Jan 21, 2017 Jan 21, 2017
Hi, I'm having this issue since i have bought Creative Cloud 2017 a month ago, Photoshop is incredibly slow (startup takes 2 to 5 minutes, it crashes and the type tool is super slow) despite my relatively strong hardware. Photoshop always resets my preferences at startup (recently opened files, imported tools and brushes, my custom workspace etc., all gone). Also workspaces won't even work (it says that the file doesn't exist everytime I select a new workspace?!!??!!?).
I tried turning it on and off again, reinstalling Photoshop, opening it as administrator, resetting the preference file, Messing with Photoshop AppData files' read only parameter on windows, none of all this works, it's getting kinda infuriating.
Thanks in advance if you have a solution!
Views
912
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 22, 2017 Jan 22, 2017
I experienced slow Photoshop behaviour in recent month after upgrading to CC2017 but that was related to Font preview which I ended up turning it off from the menu Type > Font Preview Size > None.
Try it, this could be it.
Talking about fonts, when we have hundreds or thousands of fonts in the OS, I suppose Adobe applications will take time to load all at  startup. See if you can restart your machine with basic fonts and check if Photoshop loads faster and behaves normally.
Votes
Translate
Translate
Adobe
Community Expert ,
I assuming you are on a windows platform.
Can you
Go to control panel/administrative tools/event viewer/windows logs/application and find the application error.
"copy details as text" and post them here.
Votes
Translate
Translate
Report
Report
New Here ,
There is no Photoshop application error in the windows log, Photoshop just doesn't work fine.
Votes
Translate
Translate
Report
Report
Community Expert ,
Whats your system specs?
Votes
Translate
Translate
Report
Report
New Here ,
System Information
      Time of this report: 1/21/2017, 21:20:15
             Machine name: MARIUS
               Machine Id: {9285702D-70BF-4211-8556-B259CE38DF50}
         Operating System: Windows 10 Famille 64-bit (10.0, Build 14393) (14393.rs1_release.160715-1616)
                 Language: French (Regional Setting: French)
      System Manufacturer: ASUSTeK COMPUTER INC.
             System Model: N551JX
                     BIOS: N551JX.207
                Processor: Intel(R) Core(TM) i7-4720HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
                   Memory: 8192MB RAM
      Available OS Memory: 7634MB RAM
                Page File: 11464MB used, 3755MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
       System DPI Setting: 120 DPI (125 percent)
          DWM DPI Scaling: UnKnown
                 Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Supported
           DxDiag Version: 10.00.14393.0000 64bit Unicode
Votes
Translate
Translate
Report
Report
New Here ,
Display Devices
          Card name: Intel(R) HD Graphics 4600
       Manufacturer: Intel Corporation
          Chip type: Intel(R) HD Graphics Family
           DAC type: Internal
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_8086&DEV_0416&SUBSYS_177D1043&REV_06
      Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
     Display Memory: 2160 MB
   Dedicated Memory: 112 MB
      Shared Memory: 2048 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: unknown
         Monitor Id: CMN15C4
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: Internal
        Driver Name: igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll
Driver File Version: 10.18.0015.4256 (English)
     Driver Version: 10.18.15.4256
        DDI Version: 12
     Feature Levels: 11_1,11_0,10_1,10_0,9_3,9_2,9_1
       Driver Model: WDDM 2.0
Graphics Preemption: Primitive
Compute Preemption: Thread group
           Miracast: Supported
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 17/07/2015 01:00:00, 37011384 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp: Unknown
  Device Identifier: {D7B71E3E-50DA-11CF-A56F-703718C2D835}
          Vendor ID: 0x8086
          Device ID: 0x0416
          SubSys ID: 0x177D1043
        Revision ID: 0x0006
Driver Strong Name: oem55.inf:5f63e534dd929195:iHSWM_w10:10.18.15.4256:pci\ven_8086&dev_0416&subsys_177d1043
     Rank Of Driver: 00D10001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
        DXVA2 Modes: DXVA2_ModeMPEG2_VLD  DXVA2_ModeMPEG2_IDCT  DXVA2_ModeVC1_D2010  DXVA2_ModeWMV9_IDCT  DXVA2_ModeVC1_IDCT  DXVA2_ModeH264_VLD_NoFGT  DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT  DXVA2_ModeH264_VLD_Stereo_NoFGT  DXVA2_ModeH264_VLD_Multiview_NoFGT  DXVA2_ModeHEVC_VLD_Main
   Deinterlace Caps: {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
                     {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_EdgeFiltering
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend DeinterlaceTech_BOBVerticalStretch
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY VideoProcess_AlphaBlend
       D3D9 Overlay: Not Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
           MPO Caps: Not Supported
        MPO Stretch: Not Supported
    MPO Media Hints: Not Supported
        MPO Formats: Not Supported
          Card name: NVIDIA GeForce GTX 950M
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 950M
           DAC type: Integrated RAMDAC
        Device Type: Render-Only Device
         Device Key: Enum\PCI\VEN_10DE&DEV_139A&SUBSYS_177D1043&REV_A2
     Display Memory: Unknown
   Dedicated Memory: n/a
      Shared Memory: n/a
       Current Mode: Unknown
        Driver Name: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvd3dumx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_dac0245a363caab4\nvwgf2umx.dll
Driver File Version: 21.21.0013.7254 (English)
     Driver Version: 21.21.13.7254
        DDI Version: unknown
     Feature Levels: Unknown
       Driver Model: WDDM 2.1
Graphics Preemption: DMA
Compute Preemption: DMA
           Miracast: Not Supported by Graphics driver
Hybrid Graphics GPU: Discrete
   Driver Date/Size: 11/08/2016 01:00:00, 17619464 bytes
        WHQL Logo'd: Yes
  Device Identifier: Unknown
          Vendor ID: 0x10DE
          Device ID: 0x139A
        Revision ID: 0x00A2
Driver Strong Name: oem52.inf:0f066de369c4eed8:Section126:21.21.13.7254:pci\ven_10de&dev_139a&subsys_177d1043
        Video Accel: Unknown
        DXVA2 Modes: Unknown
      Deinterlace Caps: n/a
       D3D9 Overlay: Unknown
            DXVA-HD: Unknown
         D3D Status: Not Available
         AGP Status: Enabled
           MPO Caps: Unknown
        MPO Stretch: Unknown
    MPO Media Hints: Unknown
        MPO Formats: Unknown
Votes
Translate
Translate
Report
Report
Community Expert ,
Looks like you have a laptop with a second monitor.
Main issue I see is your video card is less then what I would consider usable with Photoshop 2017
Especially for 3 D work.
8 gig of RAM is also cutting it a little close, but many basic filters and actions should still work.
Make sure you go to the ASUS website and get any driver updates for that laptop.
But the bottom line is that in  2013 is was a great laptop.
I would not expect any additional performance enhancements using PS with your system.
Sorry
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
New Here ,
Jan 23, 2017 Jan 23, 2017
Hi, I have fixed the reset bug, it was an authorization issue over the preferences folder (a normal user could not write files into it, it was at simple as that I can't believe i didn't try that earlier), and the font preview trick worked! Thanks a lot, now it works well.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
I'm glad it worked out for you.
Votes
Translate
Translate
Report
Report
