I'm hoping perhaps there's something already inside of DW CC to create that effect where you click on a link and the page automatically scrolls down to another area. I have an anchor that works but just no scrolling.
Does anyone know where I can get this simple effect in the SW or elsewhere?
Thanks for your help.
DW does not have a built-in function but it's easily done with jQuery.
OK thanks. I tried that and it doesn't seem to work. Here's the page I set up based on your link and it doesn't work. Any idea why?
<!doctype html>
<html>
<head>
<meta charset="utf-8">
<title>Untitled Document</title>
<style>
body {
font: 14px/2 Georgia, serif;
#page-wrap {
max-width: 500px;
margin: 1rem auto;
padding: 1rem;
h1, h2 {
line-height: 1.2;
p, ul, h1 {
margin: 0 0 1rem 0;
</style>
<script>
$('a[href*="#"]:not([href="#"])').click(function() {
if (location.pathname.replace(/^\//, '') == this.pathname.replace(/^\//, '') && location.hostname == this.hostname) {
var target = $(this.hash);
target = target.length ? target : $('[name=' + this.hash.slice(1) + ']');
if (target.length) {
$('html, body').animate({
scrollTop: target.offset().top
}, 1000);
return false;
</script>
</head>
<body>
<div id="page-wrap">
<h1 id="top">Smooth Page Scrolling</h1>
<ul>
<li><a href="#two">Scroll to Section Two</a></li>
<li><a href="#three">Scroll to Section Three</a></li>
</ul>
<h2 id="one">Section One</h2>
<p>Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Vestibulum tortor quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Donec eu libero sit amet quam egestas semper. Aenean ultricies mi vitae est.
Mauris placerat eleifend leo. Quisque sit amet est et sapien ullamcorper pharetra. Vestibulum erat wisi, condimentum sed, commodo vitae, ornare sit amet, wisi. Aenean fermentum, elit eget tincidunt condimentum, eros ipsum rutrum orci, sagittis tempus
lacus enim ac dui. Donec non enim in turpis pulvinar facilisis. Ut felis. Praesent dapibus, neque id cursus faucibus, tortor neque egestas augue, eu vulputate magna eros eu erat. Aliquam erat volutpat. Nam dui mi, tincidunt quis, accumsan porttitor,
facilisis luctus, metus</p>
<h2 id="two">Section Two</h2>
<p><a href="#top">Top</a></p>
<p>quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Donec eu libero sit amet quam egestas semper. Aenean ultricies mi vitae est. Mauris placerat eleifend leo. Quisque sit amet est et sapien ullamcorper pharetra. Vestibulum erat wisi, condimentum
sed, commodo vitae, ornare sit amet, wisi. Aenean fermentum, elit eget tincidunt condimentum, eros ipsum rutrum orci, sagittis tempus lacus enim ac dui. Donec non enim in turpis pulvinar facilisis. Ut felis. Praesent dapibus, neque id cursus faucibus,
tortor neque egestas augue, eu vulputate magna eros eu erat. Aliquam erat volutpat. Nam dui mi, tincidunt quis, accumsan porttitor, facilisis luctus, metus</p>
<h2 id="three">Section Three</h2>
</div>
</body>
</html>
The only way for us to see what i s going on is to see the code. You have only made us privy to the output.
At this stage I can only assume that you have not included a jQuery library in your document.
Edit:
I am also assuming that you have a working knowledge of coding (HTML, CSS and JS). If that is not the case and you don't know what a jQuery library is or how to attach it to your document, please come back here.
OK sorry about that. I went here:
http://codepen.io/chriscoyier/pen/dpBMVP
And then I created this page based on the above:
When I went to that first link it says you only need to copy the HTML and JS and CSS which is what I did but it does not work.
I you have a look at the HTML in Chris's example, you will see that it is devoid of DOCTYP, HEAD and BODY elements. This is because they are already built into the CodePen application. This means that you must add these to the example HTML if you want to put the example into your own document.
The same goes for the jQuery library which is built into the application, but needs to be put into your own document.
Just before the JS in your document, place the following code
<script src="https://code.jquery.com/jquery-3.1.1.min.js" integrity="sha256-hVVnYaiADRTO2PzUGmuLJr8BLUSjGIZsDYGmIJLv2b8=" crossorigin="anonymous"></script>
Although you see the above code on two lines, it is in fact one line.
Edit: See here jQuery CDN
Ben - I already added the doc type in my previous example. I've now added the other JS code you're saying to add. See it here:
It still does not scroll.
I think that bit of jquery may not be compatible with jquery 3+. It only appears to work with 2.1+ (see working example below).
<!DOCTYPE html>
<html>
<head>
<meta charset="UTF-8">
<title>Scroll To Section</title>
<style>
body {
margin: 0;
.nav {
display: block;
background-color: #000;
position: fixed;
width: 100%;
top: 0;
ul {
margin: 0;
padding: 0;
li {
margin: 0;
padding: 0;
display: inline;
li a {
color: #fff;
text-decoration: none;
display: inline-block;
padding: 20px;
#one {
padding-top: 60px;
</style>
<script src="http://ajax.googleapis.com/ajax/libs/jquery/2.1.3/jquery.min.js"></script>
<script>
$(function() {
$('a[href*=#]:not([href=#])').click(function() {
if (location.pathname.replace(/^\//,'') == this.pathname.replace(/^\//,'') && location.hostname == this.hostname) {
target = target.length ? target : $('[name=' + this.hash.slice(1) +']');
$('html,body').animate({
scrollTop: target.offset().top -80
}, 1000);
return false;
</script>
</head>
<body>
<nav class="nav">
<ul>
<li><a href="#one">Link 1</a></li>
<li><a href="#two">Link 2</a></li>
<li><a href="#three">Link 3</a></li>
<li><a href="#four">Link 4</a></li>
</ul>
</nav>
<section id="one">
<h2>Section 1</h2>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
<p>Section 1</p>
</section>
<section id="two">
<h2>Section 2</h2>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
<p>Section 2</p>
</section>
<section id="three">
<h2>Section 3</h2>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
<p>Section 3</p>
</section>
<section id="four">
<h2>Section 4</h2>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
<p>Section 4</p>
</section>
</body>
</html>
My previous most seems to be wrong. It looks like it is compatible with jquery v3 but you have left out the
$(document).ready(function(){
tags which need to wrap the jquery code, see below:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<style>
body {
font: 14px/2 Arial;
#page-wrap {
max-width: 500px;
margin: 1rem auto;
padding: 1rem;
h1, h2 {
line-height: 1.2;
p, ul, h1 {
margin: 0 0 1rem 0;
</style>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.1.1/jquery.min.js"></script>
<script>
}, 1000);
return false;
</script>
</head>
<body>
<ul>
</ul>
</div>
</body>
</html>
