• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
[Bug] Copying a code block causes it to disappear.
New Here ,
Jan 21, 2017 Jan 21, 2017
There is a strange bug in the new Dreamweaver. Whenever I try to select a code block, then click copy, and change windows and back again, it removes the code and replaces it with a "-".
Video here - DreamweaverBug - YouTube
Also, when you use the bottom toolbar to select code blocks, this highlighted section needs to appear in the middle of the code section. Often times it can be selected outside the view area and you struggle to find it, you have to scroll either up or down to find it.
Dreamweaver CC 2017
MacOS Sierra 10.12.2
Cheers
Views
814
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 21, 2017 Jan 21, 2017
Yep, sure is a bug, a bad one at that! Hopefull Preran​ will see this too.
Please submit it as per
Votes
Translate
Translate
Community Expert ,
Wappler, the only real Dreamweaver alternative.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Jan 23, 2017 Jan 23, 2017
I am sharing this issue with the team. Will get back to you with any updates.
Preran
Votes
Translate
Translate
Report
Report
Community Expert ,
If it's of any use to the Dev guys, I do not get the same effect following the same steps as the OP under Windows 7.
Votes
Translate
Translate
Report
Report
Community Expert ,
It may be a Windows issue. I got the same when working on a Word document. Restarted the system and the problem disappeared.
Votes
Translate
Translate
Report
Report
Community Expert ,
I just tested with SVG, PHP, CSS and HTML files and can't re-produce this behavior.
I have latest updates CC 2017.1, on Win10, 64-bit.
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Votes
Translate
Translate
Report
Report
Community Expert ,
Yep, I fell into the trap. Anything goes wrong in Dreamweaver, blame Adobe. Last night, to-night for most of you, I found the same issue using Word. Can't blame Adobe for this one, can I?
Votes
Translate
Translate
Report
Report
New Here ,
Just so everyone knows, I'm on MacOS and experiencing this bug, I use Dreamweaver multiple times every week and this has only appeared since I updated to the latest version of Dreamweaver.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Apr 18, 2017 Apr 18, 2017
LATEST
This bug appeared on the Mac when copying codes between documents but not on PC platform.
Votes
Translate
Translate
Report
Report
Engaged ,
Good grief!!!
Votes
Translate
Translate
Report
Report
