Phonegap Build fail for Android builds
huseinl9521971 Jan 22, 2017 1:20 PMHi there, I am trying to build an App using phonegap build and it seems to keep giving me the same error for Android builds. Here is the log.
Build Date: 2017-01-22 21:12:52 +0000
PLUGIN OUTPUT
Fetching plugin "cordova-plugin-whitelist" via npm
Installing "cordova-plugin-whitelist" at "1.3.1" for android
This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
Fetching plugin "phonegap-plugin-push@1.5.3" via npm
Installing "phonegap-plugin-push" at "1.5.3" for android
Fetching plugin "com.paypal.cordova.mobilesdk" via npm
Installing "com.paypal.cordova.mobilesdk" at "3.3.1" for android
Fetching plugin "card.io.cordova.mobilesdk" via npm
Installing "card.io.cordova.mobilesdk" at "2.1.0" for android
Fetching plugin "cordova-plugin-device" via npm
Installing "cordova-plugin-device" at "1.1.4" for android
Fetching plugin "cordova-plugin-inappbrowser" via npm
Installing "cordova-plugin-inappbrowser" at "1.6.1" for android
Fetching plugin "cordova-plugin-splashscreen" via npm
Installing "cordova-plugin-splashscreen" at "4.0.1" for android
Fetching plugin "cordova-plugin-geolocation" via npm
Installing "cordova-plugin-geolocation" at "2.4.1" for android
Fetching plugin "cordova-plugin-compat" via npm
Installing "cordova-plugin-compat" at "1.1.0" for android
Fetching plugin "cordova-plugin-network-information" via npm
Installing "cordova-plugin-network-information" at "1.3.1" for android
Fetching plugin "cordova-plugin-request-location-accuracy" via npm
Installing "cordova-plugin-request-location-accuracy" at "2.2.0" for android
Fetching plugin "cordova-plugin-x-toast" via npm
Installing "cordova-plugin-x-toast" at "2.5.2" for android
Fetching plugin "cordova-plugin-fastrde-checkgps" via npm
Installing "cordova-plugin-fastrde-checkgps" at "1.0.0" for android
Dependent plugin "cordova-plugin-geolocation" already installed on android.
Fetching plugin "https://github.com/rodrigo-martinezd/cordova-dialog-gps.git" via git clone
Using shallow clone
Repository "https://github.com/rodrigo-martinezd/cordova-dialog-gps.git" checked out to git ref "master" at "f110314".
Installing "cl.rmd.cordova.dialoggps" at "0.0.2" for android
Fetching plugin "https://github.com/razorpay/razorpay-cordova.git" via git clone
Using shallow clone
Repository "https://github.com/razorpay/razorpay-cordova.git" checked out to git ref "master" at "4d01a71".
Installing "com.razorpay.cordova" at "0.13.1" for android
Fetching plugin "cordova-plugin-media" via npm
Installing "cordova-plugin-media" at "2.4.1" for android
Fetching plugin "cordova-plugin-file" via npm
Installing "cordova-plugin-file" at "4.3.1" for android
Dependent plugin "cordova-plugin-compat" already installed on android.
The Android Persistent storage location now defaults to "Internal". Please check this plugin's README to see if your application needs any changes in its config.xml.
If this is a new application no changes are required.
If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
"<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
to config.xml in order for the application to find previously stored files.
Fetching plugin "cordova.plugins.diagnostic" via npm
Installing "cordova.plugins.diagnostic" at "3.3.3" for android
Fetching plugin "cordova-plugin-googlemaps" via npm
Installing "cordova-plugin-googlemaps" at "1.4.0" for android
In order to run this plugin, you need to obtain Google Maps API key for Android.
Visit https://github.com/mapsplugin/cordova-plugin-googlemaps/wiki/Installation
Check our release notes.
https://github.com/wf9a5m75/phonegap-googlemaps-plugin/wiki/Release-Notes
COMPILE OUTPUT
Configuration on demand is an incubating feature.
Incremental java compilation is an incubating feature.
:preBuild UP-TO-DATE
:preDebugBuild UP-TO-DATE
:checkDebugManifest
:preReleaseBuild UP-TO-DATE
:CordovaLib:preBuild UP-TO-DATE
:CordovaLib:preDebugBuild UP-TO-DATE
:CordovaLib:compileDebugNdk UP-TO-DATE
:CordovaLib:compileLint
:CordovaLib:copyDebugLint UP-TO-DATE
:CordovaLib:mergeDebugProguardFiles
:CordovaLib:packageDebugRenderscript UP-TO-DATE
:CordovaLib:checkDebugManifest
:CordovaLib:prepareDebugDependencies
:CordovaLib:compileDebugRenderscript
:CordovaLib:generateDebugResValues
:CordovaLib:generateDebugResources
:CordovaLib:packageDebugResources
:CordovaLib:compileDebugAidl
:CordovaLib:generateDebugBuildConfig
:CordovaLib:mergeDebugShaders
:CordovaLib:compileDebugShaders
:CordovaLib:generateDebugAssets
:CordovaLib:mergeDebugAssets
:CordovaLib:processDebugManifest
:CordovaLib:processDebugResources
:CordovaLib:generateDebugSources
:CordovaLib:incrementalDebugJavaCompilationSafeguard
:CordovaLib:compileDebugJavaWithJavac
:CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
Note: Some input files use or override a deprecated API.
Note: Recompile with -Xlint:deprecation for details.
:CordovaLib:processDebugJavaRes UP-TO-DATE
:CordovaLib:transformResourcesWithMergeJavaResForDebug
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
:CordovaLib:mergeDebugJniLibFolders
:CordovaLib:transformNative_libsWithMergeJniLibsForDebug
:CordovaLib:transformNative_libsWithSyncJniLibsForDebug
:CordovaLib:bundleDebug
:CordovaLib:preReleaseBuild UP-TO-DATE
:CordovaLib:compileReleaseNdk UP-TO-DATE
:CordovaLib:copyReleaseLint UP-TO-DATE
:CordovaLib:mergeReleaseProguardFiles
:CordovaLib:packageReleaseRenderscript UP-TO-DATE
:CordovaLib:checkReleaseManifest
:CordovaLib:prepareReleaseDependencies
:CordovaLib:compileReleaseRenderscript
:CordovaLib:generateReleaseResValues
:CordovaLib:generateReleaseResources
:CordovaLib:packageReleaseResources
:CordovaLib:compileReleaseAidl
:CordovaLib:generateReleaseBuildConfig
:CordovaLib:mergeReleaseShaders
:CordovaLib:compileReleaseShaders
:CordovaLib:generateReleaseAssets
:CordovaLib:mergeReleaseAssets
:CordovaLib:processReleaseManifest
:CordovaLib:processReleaseResources
:CordovaLib:generateReleaseSources
:CordovaLib:incrementalReleaseJavaCompilationSafeguard
:CordovaLib:compileReleaseJavaWithJavac
:CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
:CordovaLib:processReleaseJavaRes UP-TO-DATE
:CordovaLib:transformResourcesWithMergeJavaResForRelease
:CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
:CordovaLib:mergeReleaseJniLibFolders
:CordovaLib:transformNative_libsWithMergeJniLibsForRelease
:CordovaLib:transformNative_libsWithSyncJniLibsForRelease
:CordovaLib:bundleRelease
:prepareComAndroidSupportAnimatedVectorDrawable2510Library
:prepareComAndroidSupportAppcompatV72510Library
:prepareComAndroidSupportSupportCompat2510Library
:prepareComAndroidSupportSupportCoreUi2510Library
:prepareComAndroidSupportSupportCoreUtils2510Library
:prepareComAndroidSupportSupportFragment2510Library
:prepareComAndroidSupportSupportMediaCompat2510Library
:prepareComAndroidSupportSupportV132340Library
:prepareComAndroidSupportSupportV42510Library
:prepareComAndroidSupportSupportVectorDrawable2510Library
:prepareComGoogleAndroidGmsPlayServicesBase1001Library
:prepareComGoogleAndroidGmsPlayServicesBasement1001Library
:prepareComGoogleAndroidGmsPlayServicesGcm1001Library
:prepareComGoogleAndroidGmsPlayServicesIid1001Library
:prepareComGoogleAndroidGmsPlayServicesLocation1001Library
:prepareComGoogleAndroidGmsPlayServicesMaps980Library
:prepareComGoogleAndroidGmsPlayServicesTasks1001Library
:prepareComPaypalSdkPaypalAndroidSdk2146Library
:prepareComRazorpayCheckout120Library
:prepareIoCardAndroidSdk540Library
:prepareProjectCordovaLibUnspecifiedDebugLibrary
:compileDebugAidl
:mergeDebugShaders
:mergeDebugAssets
:mergeDebugResources
:processDebugResources/project/build/intermediates/res/merged/debug/values-v24/values-v24. xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
/project/build/intermediates/res/merged/debug/values-v24/values-v24.xml:4: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':processDebugResources'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 5.867 secs
Error: /project/gradlew: Command failed with exit code 1 Error output:
/project/build/intermediates/res/merged/debug/values-v24/values-v24.xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
* What went wrong:
* Try:
at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
at emitTwo (events.js:106:13)
at ChildProcess.emit (events.js:191:7)
at maybeClose (internal/child_process.js:877:16)
at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
