7 Replies Latest reply on Jan 23, 2017 10:41 PM by smacf98820054
    Phonegap build Error "oh geez your app build failed"
    smacf98820054
      APP ID: 1537206
      App was building successfully before few days. No changes are made in app but today it says "App build failed" . Following is whole stack trace
      Build Date: 2017-01-23 09:59:43 +0000
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:compileReleaseAidl
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:processReleaseManifest
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2510Library
      :prepareComAndroidSupportAppcompatV72510Library
      :prepareComAndroidSupportSupportCompat2510Library
      :prepareComAndroidSupportSupportCoreUi2510Library
      :prepareComAndroidSupportSupportCoreUtils2510Library
      :prepareComAndroidSupportSupportFragment2510Library
      :prepareComAndroidSupportSupportMediaCompat2510Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42510Library
      :prepareComAndroidSupportSupportVectorDrawable2510Library
      :prepareComGoogleAndroidGmsPlayServicesBase980Library
      :prepareComGoogleAndroidGmsPlayServicesBasement980Library
      :prepareComGoogleAndroidGmsPlayServicesGcm980Library
      :prepareComGoogleAndroidGmsPlayServicesIid980Library
      :prepareComGoogleAndroidGmsPlayServicesTasks980Library
      :prepareMeLeolinShortcutBadger114Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseAssets
      :mergeReleaseResources
      :processReleaseResources/project/build/intermediates/res/merged/release/values-v24/values- v24.xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
      /project/build/intermediates/res/merged/release/values-v24/values-v24.xml:4: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Colored'.
      FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processReleaseResources'.
      > com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/android-sdk/build-tools/24.0.1/aapt'' finished with non-zero exit value 1
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.913 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      /project/build/intermediates/res/merged/release/values-v24/values-v24.xml:3: AAPT: Error retrieving parent for item: No resource found that matches the given name 'android:TextAppearance.Material.Widget.Button.Borderless.Colored'.
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
