• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
LR6 stripping caption information when using 'Limit file size' on export. What to do?
Community Beginner ,
Jan 23, 2017 Jan 23, 2017
I have just submitted images to a news wire service and although I did a ton of captioning in Lightroom 6 the files arrives without any information attached.
They asked if I had used 'Limit File Size' on export.
I had.
I used Limit File Size to 1999k
They said Limit File Size strips all caption information.
Is this correct and if so how do I work around it? Ideally without needing to purchase Photo Mechanic.
Views
578
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
Are you sure you have the right metadata settings at Export? Exactly what metadata settings do you have selected? Show us a screen capture!
Votes
Translate
Translate
Report
Report
Good idea thanks! However I sent the photos out two days ago. I have since changed some of the export information. I will take a look and see what's set right now, however it may not be the same.
What settings should I have selected?
Votes
Translate
Translate
Report
Report
LEGEND ,
The dropdown menu should be set to All.
Votes
Translate
Translate
Report
Report
Hi again...okay I see right now I have  ALL METADATA selected but the boxes REMOVE PERSON INFO AND REMOVE LOCATION INFO are checked.
Would that have removed all captioning?
Evidently I need to uncheck those boxes. (rolling eyes emoji)
So does that mean that Limit File Size does NOT strip caption information?
Votes
Translate
Translate
Report
Report
LEGEND ,
I have not investigated this, you are fully in a position to investigate this, but honestly I think that the idea that the file size limitation will remove metadata is either a bug, or nonsense, probably the latter.
Votes
Translate
Translate
Report
Report
dj_paige not sure if you saw my reply. I sent it at the same time you sent yours.
Thank you for pointing me in this direction. Duh. Embarrassing...
Just to repeat in case you missed my last message...
I do have it set to ALL but the boxes REMOVE PERSON INFO AND REMOVE LOCATION INFO are checked.
Would that have stripped all caption information?
Have you ever heard it mentioned that Limit File Size strips caption information? You may have just saved me $150 if I don't need to purchase Photo Mechanic Thanks!
Votes
Translate
Translate
Report
Report
LEGEND ,
Why don't you try it and tell us. I just did using LR CC 2015.8 and the Caption data is NOT deleted.
Votes
Translate
Translate
Report
Report
I just tried it with the boxes checked as well as unchecked and don't see a difference.
Votes
Translate
Translate
Report
Report
I don't know how to delete this post. I don't want to spread false information and I believe that what I was told is false so moderators feel free to delete this! Thanks.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
The post is useful since clearly there is a problem somewhere. I suggest contacting your news wire service and letting them know it has been confirmed the IPTC Caption data is NOT removed during LR Export with 'Limit File Size' selected. Have them explain what specific IPTC or EXIF data field(s) are missing.and have them send you a copy of a file with this issue. We can then investigate further as to what's happening.
Votes
Translate
Translate
Report
Report
