4 Replies Latest reply on Jan 27, 2017 12:53 AM by nathans47916809
    Reg:Problem in Save as PDF
    nathans47916809 Level 1
      Dear Friends,
        I am Using Adobe illustrator CC(17.1).
        I have faced a problem while using adobe_saveACopyAs for saving as PDF.
        I am trying to Apply Fill Color for a path and Save it as PDF.
        The Fill is not shown in the ai file and saved PDF file After the execution of the following line
        sAIActionManager->PlayActionEvent( "adobe_saveACopyAs", kDialogOff, valueParameterBlock);
        Please note that:
        The Folllowing line is not used(commented) then Fill is Shown in ai file.
        Please give your suggestion to save As PDF with Fill.
        Thank you friends,
        Nathan
        • 1. Re: Reg:Problem in Save as PDF
          LeoTaro Level 4
          Could you post more code? When is this code called, in response to a message or some callback?
          • 2. Re: Reg:Problem in Save as PDF
            Dear Friend,
              Thank you for your Immediate reply.
              The Code for save as PDF I have written as follows,
            AIActionParamValueRef paramValueRef = NULL;
            sAIActionManager->AINewActionParamValue(&paramValueRef);
            sAIActionManager->AIActionSetString( paramValueRef,  'name', "D:\\MySample.pdf" );
            sAIActionManager->AIActionSetString( paramValueRef, 'frmt', kAIPDFFileFormat);
            sAIActionManager->AIActionSetString( paramValueRef, 'extn', kAIPDFFileFormatExtension);
            sAIActionManager->AIActionSetInteger( paramValueRef, 'gprm', 1);
            sAIActionManager->PlayActionEvent( "adobe_saveACopyAs", kDialogOff, paramValueRef);
            Regards,
            Nathan
            • 3. Re: Reg:Problem in Save as PDF
              A. Patterson Level 4
              Try adding this line:
              sAIActionManager->AIActionSetBoolean(paramValueRef, kAIExportDocumentSaveMultipleArtboardsKey, 0);
              I had trouble in the past making this action work without that value being set.
              • 4. Re: Reg:Problem in Save as PDF
                Dear Friend,
                Thank you For Your suggestion.
                I am try with the code you mentioned,as like below
                sAIActionManager->AIActionSetBoolean(paramValueRef, 'smab', 0);
                But the Problem is not solved.
                Regards,
                Nathan
