3 Replies Latest reply on Oct 19, 2008 10:12 PM by Newsgroup_User
    Very basic array question
    SiHoop
      The following code traces:
      Original=1,2,3
      New=1,2
      Original=1,2
      New=1
      Original=1
      New=
      How is it possible for the value of the array firstArray to change?
        • 1. Re: Very basic array question
          *gsb* Level 1
          This is because the variable, firstArray, holds a 'pointer' to the array and not the array data. So, the expression:
          secondArray = firstArray
          ...sets up a new pointer to the same data.
          You want to use a "copy firstArray into a new space and call it secondArray ."
          • 2. Re: Very basic array question
            John Hall Level 4
            A bit more detail; if you're using Boolean, String, int, uint or Number, when you assign one variable to another, it makes a true copy of the value. For other things, like arrays, custom objects, objects, etc. it is, as gsb said, simply a pointer or reference to the original object so anything you do to the 'copy' actually acts on the original. Look up 'cloning arrays' in Flex help.
            • 3. Re: Very basic array question
              Level 7
              "SiHoop" <webforumsuser@macromedia.com> wrote in message
              news:gdfovg$h8r$1@forums.macromedia.com...
              > Original=1,2,3
              > New=1,2
              > Original=1,2
              > New=1
              > Original=1
              > New=
              Because firstArray and secondArray are the same thing. If you read the
              Array documentation, this is spelled out VERY clearly.
              http://www.adobe.com/livedocs/flex/3/langref/Array.html
