4 Replies Latest reply on Jan 25, 2017 5:12 AM by Russ Ward
    Is it possible to run an ExtendScript function from the FDK?
    Ian Proudfoot Adobe Community Professional
      I have created an ExtendScript function that builds and populates a ScriptUI dialog. It then opens a template selected by the user. This works well and does everything I want it to do. Now the problem is that I need to run it from an FDK menu. This ExtendScript function takes a single argument.
      I though that F_ApiCallClient() would be the way to go, but it's not documented for that usage. Has anyone tried to do this and succeeded? Or perhaps I'm overlooking a really obvious way to do it?
      Ian
        • 1. Re: Is it possible to run an ExtendScript function from the FDK?
          Wiedenmaier Level 3
          Ian,
          strange, we had the same question a week ago in FrameDev-Yahoo Group. So I can copy + paste:-)
          There is not Chance to provide parameters with F_ApiCallClient(). One solution was to write a temporary file in your FDK Client and read this within your ES. I would recommend to write to JSON Format for more complex data structure, as you can use eval() to deserialize this data to an object model very easily.
          Few year's ago, I implemented a solution with F_ApiHypertext which works very well:
          In your plugin call following, where you call F_ApiCallClient now
          F_Sprintf((StringT)message, "message ScriptingSupport Notification FA_Note_PreFunction: docid:<%d> sparm:<%s> iparm:<%d>", docId, sparm, iparm);
          F_ApiHypertextCommand(0, message);
          F_ApiHypertextCommand can be called anywhere in your script, of course. The message string doesn’t matter. You only need a rule in your script which can handle and parse this
          In your script register for “Constants.FA_Note_PreHypertext” and implement Notify-callback which catches this Event
          if (sparm.substring(0, “message ScriptingSupport Notification FA_Note_PreFunction:”.length) == “message ScriptingSupport Notification FA_Note_PreFunction:”)
              //FA_Note_PreFunction Notification was raised by fdk client
              OnHyperTextNotification(Constants.FA_Note_PreFunction, sparm) ;
          function  OnHyperTextNotification(notification, str)
              var idxDocId = str.indexOf("docid:<") + "docid:<".length;
              var idxSParm = str.indexOf("sparm:<") + "sparm:<".length;
              var idxIParm = str.indexOf("iparm:<") + "iparm:<".length;
              var docid = str.substr(idxDocId).substr(0, str.substr(idxDocId).indexOf(">"));
              var sparm = str.substr(idxSParm).substr(0, str.substr(idxSParm).indexOf(">"));
              var iparm = str.substr(idxIParm).substr(0, str.substr(idxIParm).indexOf(">"));
               //invoke Notify or do anything else
              Notify (notification, docid, sparm, iparm) ;
          I don’t know yet, if it’s possible to get a return value back from ES to FDK.
          I hope this is useful
          Markus
          • 2. Re: Is it possible to run an ExtendScript function from the FDK?
            Thank you Markus,
            Ingenious, will try that tomorrow!
            Regards
            Ian
            • 3. Re: Is it possible to run an ExtendScript function from the FDK?
              Hello Markus,
              Once again thank you for the ideas. In the end I changed the scope of the script so that it created its own menu command. I will try your ideas later when I have more time.
              Best regards
              Ian
              • 4. Re: Is it possible to run an ExtendScript function from the FDK?
                Russ Ward Level 4
                That hypertext command solution is really very clever, Markus. I suspect that it is just a fortunate accident that FrameMaker allows this interaction between an FDK client and an ES script. Congratulations for finding it.
                Russ
