13 Replies Latest reply on Jun 9, 2017 9:45 AM by pixxxel schubser
    Save in directory based on filename.
    kareyh56356757
      I am very new to scripting.  I am looking to create a script that will save a .tif file with LZW compression to a file in a directory based on the current image filename.  If that directory doesn't exist it will create it.  All of my filenames are based on a 7 digit system.
      For example... I want to take file name  "123-456_A"  and put it in the following folder system...
      Product(Starting folder on the server)
      -1
      --12
      ---123
      ----123-
      -----123-4
      ------123-45
      -------123-456(Final Folder)
      The "_A" etc will be ignored. Is this possible?
        • 1. Re: Save in directory based on filename.
          c.pfaffenbichler Level 9
          Please post screenshots illustrating the task and Folder structure better.
          And please explain what exactly you mean by
          Save a copy of the active File? Save the active File as a new file?
          With Layers or flattened?
          • 2. Re: Save in directory based on filename.
            kareyh56356757 Level 1
            Would be saving the active file as a new file with the following TIF options.
            • 3. Re: Save in directory based on filename.
              pixxxel schubser MVP & Adobe Community Professional
              kareyh56356757,
              a folder hierarchy like yours doesn't make any sense for me, sorry. But anyway, try this:
              // folder_saveTif_inFolderBasedOnFilename.jsx
              // https://forums.adobe.com/thread/2268221
              // regards pixxxel schubser
              // only file names eg 123-456_A or 100-123_Z allowed
              var aDoc = activeDocument, nme = aDoc.name.replace(/\.[^\.]+$/,""), reg = /^\d{3}-\d{3}_./, tmp = nme.split("");
              checkAndSave();
              function checkAndSave() {
                  if( reg.test( nme ) == false) {
                      alert ("wrong file name"); return; }
                  else { tmp.splice(3,1); tmp.splice(-2); tmp[2] += "-";
                      for( i = 1; i < 6; i++ ) { tmp[i] = tmp[i-1] + tmp[i]; };
                      var saveFol = Folder ("~/Desktop");
                      for ( i = 0; i < tmp.length; i++ ) {
                          saveFol = Folder( saveFol + "/" + tmp[i] );
                          if (!saveFol.exists) { saveFol.create() };
                  var saveName = "/" + nme + ".tif";
                  var saveFile = new File( saveFol + saveName );
                  if( saveFile.exists ) { alert( saveFile + "\nFile already exists - not saved now" ); return; };
                  saveAsTIFF( saveFile ); alert( saveFol + saveName + " saved" )
                  //aDoc.close( SaveOptions.DONOTSAVECHANGES );
                  }; return;
              function saveAsTIFF( saveFile ) {
                  tiffSaveOptions = new TiffSaveOptions();
                  tiffSaveOptions.layers = true;
                  tiffSaveOptions.imageCompression = TIFFEncoding.TIFFLZW;
                  activeDocument.saveAs( saveFile, tiffSaveOptions, false );
              This snippet should create the wished folder hierarchy (on your desktop) based on the given example file name.
              Have fun
              • 4. Re: Save in directory based on filename.
                I didn't design the folder system.... I just have to use it   Is there anyway I can set an absolute path(?) that points to a location on a sever verses the desktop? I am on a Mac and tried putting in the path but it just returns and error.
                • 5. Re: Save in directory based on filename.
                  I should add that it is an smb:// path
                  • 6. Re: Save in directory based on filename.
                    kareyh56356757,
                    what is the problem?
                    At first: I'm not really familiar with Mac OS and server paths.
                    Do you have a screenshot of the part of your desktop which shows your server icon?
                    Eg the name of the icon is "Transfer". Maybe this name is different to the real name of the server (eg sxyztech)
                    One possible way to find the path is: open a file which is located directly on Transfer/yourExampleFile.psd
                    Run this line of code:
                    alert(activeDocument.path)
                    On your Mac you should get now a result like this:
                    /Transfer/yourExampleFile.psd
                    And now you can try to replace this line of my code:
                    with this:
                    var saveFol = Folder ("/Transfer");
                    Perhaps this helps you to find your way.
                    Have fun
                    And give a feedback please. I'm very interested for your answer.
                    • 7. Re: Save in directory based on filename.
                      That worked great to find the correct path.  Thank you!  One thing that I have noticed is that it is creating the "100-" folder in the wrong place.   This is so close and I am very grateful!
                      It should show up as the highlighted folder above but instead it is showing as "100-"  where it should be "100".
                      To add complication, my predecessor deviated from the folder system in spots.  In the example below the "203-" folder was skipped and went directly into the "203-X" numbering.
                      Because all of these files are linked to another program I can't change the existing structure.  I can make sure it is correct going forward but not anything that is already there.  Is there anyway to include an "If" or "else" to take this into account?  I realize this is asking a lot and I may have to manual correct these items.
                      Thank you so much for your help so far!  This has been the absolute closest I have come to making his script a reality after lots of trial and error.
                      • 8. Re: Save in directory based on filename.
                        The first one is easy.
                        Replace line #12 and #13 in my code with:
                            else { tmp.splice(-2); //tmp.splice(3,1); tmp.splice(-2); tmp[2] += "-";
                                for( i = 1; i < 7; i++ ) { tmp[i] = tmp[i-1] + tmp[i]; };
                        Have fun
                        The second part is more complex. Sorry but I don't want spend time for check this now.
                        Furthermore it is another question.
                        • 9. Re: Save in directory based on filename.
                          Thank you for all of your help!  It is very appreciated!!!
                          • 10. Re: Save in directory based on filename.
                            This script has been working perfect for me!  Is there a way to alter it for files that have a naming structure of ZZ12345_A ?  Basically I want it to read any 7 digit filename and put it in the coordinating folder.
                            • 11. Re: Save in directory based on filename.
                              Hi kareyh56356757,
                              hmmh?
                              ZZ12345_A is not a 7 digit filename.
                              Furthermore:
                              which letters and/or digits in the filename are fix and which ones are variable?
                              • 12. Re: Save in directory based on filename.
                                I realized my mistake and fixed it with the following...
                                var aDoc = activeDocument, nme = aDoc.name.replace(/\.[^\.]+$/,""), reg = /^\w{2}\d{5}_./, tmp = nme.split("");
                                checkAndSave();
                                I had been trying to read the letters as digits.
                                • 13. Re: Save in directory based on filename.
                                  Regex is not easier way off. You should understand the syntax before.
                                  Try this snippet (standalone):
                                  var a = "1234567_A";
                                  var b = "ZZ12345_A";
                                  var  nme = a.replace(/\.[^\.]+$/,""), reg = /^\w{2}\d{5}_./, tmp = nme.split("");
                                  checkAndSave();
                                  nme = b.replace(/\.[^\.]+$/,""), reg = /^\w{2}\d{5}_./, tmp = nme.split("");
                                  checkAndSave();
                                  nme = a.replace(/\.[^\.]+$/,""), reg = /^[A-Z]{2}\d{5}_./, tmp = nme.split("");
                                  checkAndSave();
                                  nme = b.replace(/\.[^\.]+$/,""), reg = /^[A-Z]{2}\d{5}_./, tmp = nme.split("");
                                  checkAndSave();
                                          alert (reg+" better regex do not find: "+ nme); return; }
                                      else { alert (reg+" found: "+nme) }
                                  The reason is: \w will find all "word signs" eg digits AND letters
                                  Have fun
