7 Replies Latest reply on May 12, 2017 7:57 AM by garryl15493042
    Problem icon windows 10 submit on the store
    yohannk19562278 Level 1
      I have a small problem with the icons on windows 10 ! I search in a lot of forum but any solution work!
      So when i submit i have this error :
      • Image file StoreLogo.scale-100.png is a default image.
      • Image file Square150x150Logo.scale-100.png is a default image.
      • Image file Square310x310Logo.scale-100.png is a default image.
      In my config.xml i have that :
      <platform name="windows">
      <icon src="res/icon/windows/StoreLogo.scale-100.png" platform="windows" width="50" height="50"  />
      <icon src="res/icon/windows/Square150x150Logo.scale-100.png" platform="windows" width="150" height="150" />
      <icon src="res/icon/windows/Wide310x150Logo.scale-100.png" platform="windows" width="310" height="150"  />
      <icon src="res/icon/windows/Square310x310Logo.scale-100.png" platform="windows" width="310" height="310"   />
      </platform>
      And my zip is like that :
      • CSS
      • IMG
      • JS
      • RES
           • ICON
                     • windows
           • .pgbomit
      • config.xml
      • index.html
      One of you have the solution ?
        • 1. Re: Problem icon windows 10 submit on the store
          kerrishotts Adobe Community Professional
          Are you using PhoneGap Build?
          Also -- make sure that the path exists and the case matches exactly. "RES/ICON/windows" (going by your structure above) can be different than "res/icon/windows", depending upon the file system and OS.
          • 2. Re: Problem icon windows 10 submit on the store
            Yes i'm using PGB
            How can i check this ?
            I build with the last version of PGB for Windows 10 signing
            • 3. Re: Problem icon windows 10 submit on the store
              What OS are you using on your development machine?
              • 6. Re: Problem icon windows 10 submit on the store
                garryl15493042 Level 1
                I'm getting exactly the same problem with PhoneGap Build (PGB).
                My config.xml:
                      <icon src="icons/windows/Square150x150Logo.png" target="StoreLogo" />
                      <icon src="icons/windows/smalllogo30x30.png" target="Square30x30Logo" />
                      <icon src="icons/windows/Square44x44Logo.png" target="Square44x44Logo" />
                      <icon src="icons/windows/Square70x70Logo.png" target="Square70x70Logo" />
                      <icon src="icons/windows/Square71x71Logo.png" target="Square71x71Logo" />
                      <icon src="icons/windows/Square150x150Logo.png" target="Square150x150Logo" />
                      <icon src="icons/windows/Square310x310Logo.png" target="Square310x310Logo" />
                      <icon src="icons/windows/Wide310x150Logo.png" target="Wide310x150Logo" />
                    </platform>
                The response from certification from Microsoft:
                FAILED
                Branding
                • Error Found: The branding validation test encountered the following errors:
                  • Image file Square30x30Logo.scale-100.png is a default image.
                  • Image file Square70x70Logo.scale-100.png is a default image.
                  • Image file Wide310x150Logo.scale-100.png is a default image.
                • Impact if not fixed: Windows Store apps are expected to be complete and fully functional. Apps using the default images e.g. from templates or SDK samples present a poor user experience and cannot be easily identified in the store catalog.
                • How to fix: Replace default images with something more distinct and representative of your app.
                It seems as though the icon specifications in config.xml is being ignored.
                • 7. Re: Problem icon windows 10 submit on the store
                  I seem to have resolved the problems with icons so here are my sections from my config.xml file:
                  <!-- http://stackoverflow.com/questions/35313761/windows-10-icons-in-cordova-config-xml -->
                        <icon src="icons/windows/Square150x150Logo.png" target="StoreLogo"         width="150"  height="150"  />
                        <icon src="icons/windows/smalllogo30x30.png"    target="Square30x30Logo"   width="30"   height="30"   />
                        <icon src="icons/windows/Square44x44Logo.png"   target="Square44x44Logo"   width="44"   height="44"   />
                        <icon src="icons/windows/Square70x70Logo.png"   target="Square70x70Logo"   width="70"   height="70"   />
                        <icon src="icons/windows/Square71x71Logo.png"   target="Square71x71Logo"   width="71"   height="71"   />
                        <icon src="icons/windows/Square150x150Logo.png" target="Square150x150Logo" width="150"  height="150"  />
                        <icon src="icons/windows/Square310x310Logo.png" target="Square310x310Logo" width="310"  height="310"  />
                        <icon src="icons/windows/Wide310x150Logo.png"   target="Wide310x150Logo"   width="310"  height="150"  />
                        <icon src="icons/windows/360x360.png"                                      width="360"  height="360"  />
                        <icon src="icons/windows/106x106.png"                                      width="106"  height="106"  />
                        <icon src="icons/windows/170x170.png"                                      width="170"  height="170"  />
                        <icon src="icons/windows/50x50.png"                                        width="50"   height="50"   />
                        <icon src="icons/windows/120x120.png"                                      width="120"  height="120"  />
                        <icon src="icons/windows/744x360.png"                                      width="744"  height="360"  />
                      </platform>
                      <!-- http://stackoverflow.com/questions/38784047/phonegap-windows-app-image-issue -->
                      <platform name="winphone">
                      </platform>
