I need to have text over an image (as shown below), however the text has turned transparent. How can I ensure the text still remains black?
This screenshot below shows the original text before it is dragged onto the image.
Check the blending mode of the text – select the text then: Object > Effects > Transparency – Mode
What Adobe program are you using?
InDesign
I've moved it over to that forum.
Thank you!
Have you checked your text wrap?
Yes, I have clicked on all options and it is not making any difference. Any other suggestions?
for example put "normal"
It has worked! Thank you so much!
