The Adobe Sign feature list says that all versions support "Send, track, and manage directly from your online Box or Google Drive account". Where are the configuration instructions for Google Drive? I see nothing in the help or forums.
Hi williamb15299553​,
Yes, you can integrate Box or Google Drive account with your Adobe Sign account.
Login to your Adobe Sign account using the below link:
- Sign In — e-signature and e-sign Software Solution — Adobe Sign
Navigate to Send Page -> Add files -> Select the account you want to integrate and login with the account details to complete the integration.
Regards,
Aadesh
Regards,
Aadesh
Hi William.
Did this work for you? I would like this feature as well.
Chris
In my experience, this allowed me to use a Google Drive file in Adobe Sign, but I wouldn't call it a full integration. The AS document does not live in Google Drive as it makes its way through the workflow. The final document also does not appear in Google Drive. If I'm missing something here, I'd love to know how to make the full integration happen!
same here, any answer to this?
Tried to connect my Google Account and received the following error, "Sing in with Google temporarily disabled for this app...This app has not been verified yet by Google in order to use Google Sign In."
We are aware of this issue. This is due to a change at Google's end and we have already filled a form with Google to get this working again. Unfortunately, At the moment, there is no workaround available for the issue. Will update the thread once the issue is fixed.
Sameer Puri
Any updates?
Any Fix on this yet?
Hi admin​ - can we please have an update on this issue from - last I can see is from Sameer Puri in June?
Also having this problem, any status at this point?
Hello All,
The issue "Sign in with Google temporarily disabled for this app" should be fixed now. Please give it a try and let us know any issue (with screenshots) you might face while trying this workflow.
Sameer Puri
I have a similar problem. I have linked my google drive account but when i click to access a file i get a big blank white square and nothing else. Please advise?
Hi Matthewc,
As you have mentioned above, you get the blank window when you select the Google Drive to add a document.
Please try once to clear the cache and cookies of the browser.
Try to open the application on an alternate browser or the new incognito window on Chrome.
Let us know if you still experience the issue.
Regards,
Meenakshi
Same issue on Firefox and incognito window after clearing cache and cookies.
Lu Schlang
Personal information deleted by moderator
Hi Matthewc,
Sorry for the delay in response.
The issue has been resolved.
Would you please check if you can upload the document from Google Drive now?
Let us know if you experience any issue.
Regards,
Meenakshi
I couldn’t wait this long, cancelled the account.
Sent from my iPhone
Too little too late! I canceled my subscription.
A R T W I T H M E T U L U M
Lu Schlang
lu@artwithme.org
+1 917.705.9417
www.artwithme.org
Can you access Google Team Drive files? I having trouble doing this from Adobe Sign. I can access non Team Drive files, but when I search for a file name that is in a Team Drive, it doesn't come up.
I was testing out functionality on a shared Adobe Sign account and connected it to my Google Drive to see the functionality, but now I can't figure out how to remove it (since it's a shared account). Please advise.
I have a similar issue. We curently use Dropbox and I can go in through Dropbox, share document, use Adobe Sign and once the file it sent, it asks where I would like the file to be saved once signed in dropbox.
We are looking to move to Good Drive and I can not find a similar feature to save the documents in Good Drive.
Can anyone help?
I would also like to integrate our Google Drive account with our Adobe Sign Enterprise account. Can we set up folders within Google Drive so that signed PDFs from webforms can automatically store in Google Drive with an assigned folder? Are there any APIs that help with this sort of automatic storage?
