• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Image quality poor when saving from Lightroom
Community Beginner ,
Jan 25, 2017 Jan 25, 2017
Hi all
I'm a novice in both photography and the Adobe products but am fast becoming addicted.  Anyway, I have noticed that when I save my crisp, edited images from Lightroom, the quality of the image drops dramatically.  I'm attaching a screen shot of both the Lightroom image as I would like it to appear and the saved version plus my save settings.  Many thanks for your help with this newbie.  - Melissa
Views
3.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 25, 2017 Jan 25, 2017
melking_1978 wrote:
Yes correct. I'm not using any software to open the image, just double clicking on the jpeg image I've saved to my Mac desktop.
You are using software in that case. You are using Apple's preview. It is fully color managed but uses a different scaling algorithm to scale down large images to the much lower resolution of your display than Lightroom does. This will make images appear much softer than they looked in Lightroom. If you export in 16 bit tiff, your images will be very
Votes
Translate
Translate
LEGEND ,
I assume the right hand image is in Lightroom, and the left hand image is after you do an Export from Lightroom. Is that correct?
Please tell me what software you are using to view the photo outside of Lightroom.
Votes
Translate
Translate
Report
Report
Votes
Translate
Translate
Report
Report
Community Expert ,
You are using software in that case. You are using Apple's preview. It is fully color managed but uses a different scaling algorithm to scale down large images to the much lower resolution of your display than Lightroom does. This will make images appear much softer than they looked in Lightroom. If you export in 16 bit tiff, your images will be very close to identical to what you have  inside Lightroom. What you should try is to actually scale down to a much lower resolution sRGB jpeg (say 800 pixels on the long side) and to use output sharpening. You'll see it will look very crisp.
Votes
Translate
Translate
Report
Report
LATEST
Thanks so much.  It seems to have worked!
Votes
Translate
Translate
Report
Report
LEGEND ,
Mac or Windows? What version?
Which exact version of Lightroom?
What image viewer are you using? Is it color managed?
Saving the color space as sRGB might be better depending on your usage.
Turning on the output sharpening is usually required for good results.
Votes
Translate
Translate
Report
Report
It's version Lightroom 5, on a MacBook Air.  Not sure what you mean by image viewer...  I'm literally just double clicking in my image which is saved on my desktop.  Is this where I'm going wrong??  Thanks, appreciate the help
Votes
Translate
Translate
Report
Report
LEGEND ,
Export with color space set to sRGB
Votes
Translate
Translate
Report
Report
Community Expert ,
To do a valid comparison you have view both images at 1:1 (100%) view, where on image pixel is represented by one screen pixel.
Different applications use different smoothing and sharpening algtorithms when scaling the image, resulting in an apparent difference in sharpness.
Votes
Translate
Translate
Report
Report
Community Expert ,
When exporting the way you did, with no image resizing and no output sharpening, the images should be equally sharp when viewed at 1:1.
But there is a slight tonal difference between the images, which could be due to the Adobe RGB profile.
As others have suggested, try using the sRGB profile instead.
Votes
Translate
Translate
Report
Report
