2 Replies Latest reply on Jan 26, 2017 10:17 AM by lameduck02
    License Server Communication Problem?
    lameduck02
      E.Act-Not-Ready    ?????
      Case #0220947073
        • 1. Re: License Server Communication Problem?
          Nanaky Level 5
          Windows:
              Close all applications.
              Choose Start > Run.
              In the Open text box, type regedit and then press Enter. The Registry Editor opens.
              In the left pane of the Registry Editor, locate the following registry key: HKEY_CURRENT_USER\Software\Adobe\Adept
              Select the Adept key.
              Choose File > Export.
              In the Export Registry File dialog box, select Selected Branch under Export Range. Enter a name and location for the backup registry key, and then click Save.
              Right-click the Adept key and choose Delete.
              In the Confirm Key Delete dialog, click OK.
              Close the Registry Editor.
              Open Adobe Digital Editions and reauthorize.
          Macintosh:
              quit Adobe Digital Editions.
              Navigate to /Users//Library/Application Support/Adobe/Digital Editions and drag the activation.dat file to the trash.
              If you are using 10.7, see https://helpx.adobe.com/x-productkb/global/access-hidden-user-library-files.html
          The Case numer help only the Adobe Staff Person.
          • 2. Re: License Server Communication Problem?
            lameduck02 Level 1
            Thank you! Only one correction: on Macs using 10.7, it applies to 10.7 and above. Not being picky, just so every one knows and do not get led astray.
