Hello all,
I've created an interactive form in InDesign (current version), nad when I export the form there's a few problems I'm having. Perhaps you can help?
I created text boxes, applied a border stroke to them, and then converted the text box to a form field, set for "text" and multiline. However, when the form exports all I see is a purple/blue box with no stroke. I'd love to just have the stroked box with no background at all, or at the very least the colored box with the stroke I set.
If I export the form as a regular print pdf (non-interactive), the border stroke doesn't show up either. The only way I can get the border stroke to appear is if I convert the interactive field back to a regular (non interactive) object. Any help to get me where I want to be? Thanks!
-jon
Or, it may be easier to edit the form field and add the stroke in Acrobat Pro:
Borders around form fields just don't carry over iinto the PDF.
Instead, duplicate the text frame and put the copy behind the form field. Stroke the copy instead. You may need to set the stroke to Align Stroke to Outside.
