0 Replies Latest reply on Jan 25, 2017 2:34 PM by msdobrescu
    PIProperty proper handling?
    msdobrescu Level 1
      Hello,
      I've seen this:
      /** Plug-in property. Properties contain information about
          plug-in resource files, such as their type and location. */
      typedef struct PIProperty {
          /** Vendor-specific identifier. */
          PIType vendorID;
          /** Identification key for this resource type. */
          PIType propertyKey;
          /** 0-based index of this resource within its type.
               Must be unique for properties of a given type within
               a property list. */
          ai::int32 propertyID;
          /** Number of characters in the data array. Rounded to a multiple of 4. */
          ai::int32 propertyLength;
          /** The property data array that contains the property value, a string of 4 characters. */
          char propertyData[1];
      } PIProperty;
      where "char propertyData[1];" should contain more than 1 char.
      How is a correct memory handling for it? I assume it will contain a long string when it is used as [out] parameter.
      How to avoid memory leaks?
      How sould be initialized correctly when it is used as [in] parameter?
      Thank you.
