5 Replies Latest reply on Jan 27, 2017 5:10 AM by jon@indicator
    Problem adding an anchored text frame into a duplicated paragraph
    jon@indicator
      I don't understand in which paragraph my new text frame is added,
      Here is my code:
      function buildFrameBox(para)
           var copyPara = para.duplicate(LocationOptions.AFTER, para),
           frame;
           $.writeln(para.textFrames.length + ':' + copyPara.textFrames.length); // 0:0
           app.findGrepPreferences = NothingEnum.NOTHING;
           app.changeGrepPreferences = NothingEnum.NOTHING;
           app.findGrepPreferences.findWhat = "[^\r]"; // Remove anchor character
           app.changeGrepPreferences.changeTo = '';
           copyPara.changeGrep(); // Remove all content in my new paragraph except line break
           frame = copyPara.insertionPoints.firstItem().textFrames.add();
           frame.textFramePreferences.autoSizingType = AutoSizingTypeEnum.HEIGHT_AND_WIDTH_PROPORTIONALLY;
           frame.contents = 'Some text here';
           $.writeln(para.textFrames.length + ':' + copyPara.textFrames.length); // 1:0
           return frame;
      The question is: If I am adding a text frame into the duplicated paragraph, why does it say that original paragraph contains a text frame while the duplicated has no frames at all?
      In my InDesign document script works fine and text frame is placed where I want.
      Thanks in advance for your help.
        • 1. Re: Problem adding an anchored text frame into a duplicated paragraph
          Peter Kahrel Adobe Community Professional & MVP
          If your script works fine, what's the problem?
          Anyway, this line:
          matches anything that's not a \r. Maybe that's the problem.
          • 2. Re: Problem adding an anchored text frame into a duplicated paragraph
            jon@indicator Level 1
            Thanks for your reply.
            What I am trying to do is to create a textFrame where some paragraphs should be moved into.Also, I need to be careful when moving paragraphs that already contain textFrames.
            After the code quoted above, I want to move my original paragraph into that textFrame.
            So, the textFrame is created as expected.
            The problem is that the original paragraph contained 0 textFrames and after that code is run it contains 1 textFrame.
            But I expected original paragraph to contain 0 textFrames and the copy paragraph to contain 1.
            So I am wondering if there is any problem with InDesign DOM.
            The grep code is what I want so in my doc I got:
                 Original Paragraph \r
                 Text Frame \r
            Thanks a lot for having a look into it.
            • 3. Re: Problem adding an anchored text frame into a duplicated paragraph
              Loic.Aigon Adobe Community Professional
              Well technically it would match anything that's not the "r" character
              • 4. Re: Problem adding an anchored text frame into a duplicated paragraph
                dumitrus56120735
                Hello!
                My name is Dumitru.
                I work on design on books, and thus trying for a while to compose a GREP for subtitles to ease mai work load, but no success.
                I have the Paragraph Styles and I can do the Character Styles for these subtitles with no dot “.“ at the end of them, of course.
                I believe all my best was: ^[\(\u+\l+\d]\.\)+r but it did not work. At least I figured I need one GREP for each subtitle, because my subtitles are all different!
                Examples of what subtitles I need is this:
                • Body text.... body text...body text...
                          subtitle: I. subtitle
                          subtitle: A. new subtitle
                          subtitle: 1. new subtitle
                          subtitle: a. new subtitle
                          subtitle: 1) new subtitle
                          subtitle: a) new subtitle
                          subtitle: (1) new subtitle
                          subtitle: (a) new subtitle
                I felt I am close but I just could not make it. So, I said I will ask people who really know this wonderful function of InDesign otherwise, GREP.
                Thank you.
                • 5. Re: Problem adding an anchored text frame into a duplicated paragraph
                  Yes,
                  Sorry, that line was wrong
                  It should be:
                  app.findGrepPreferences.findWhat = "[^\\r]"; // Remove everything except \r
                  However the problem/question about the number of textFrames in original paragraph remains.
                  Thanks a lot for your reply.
