• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
BC Blog Module
Community Beginner ,
Jan 26, 2017 Jan 26, 2017
Hi Guys
Sorry I'm a newbie to BC and Muse however I have created a site in Muse and came across the BC blogging module which i have incorporated into my Muse site using embedded HTML and the {tag_pagecontent} as suggested by BC.
I have the blog formatted to match the rest of the site and it works fine. Although when I add a new post using the Blog Module in BC the text does not format.
For example If i want to bullet point a load of text I can select the text and click the bullet point tool, however this does not show in the design window and nor does it format the text in the Blog. Also if i select a text and make it bold this will not show up on the website when published.
I have spoken the BC help and they say that it is a conflict with my template which would sort of make sense but as i cannot see text being formatted in the blog module design window i think this is a BC side issue. Has anyone else had the same or similar problem and if so can you help explain what the problem could be.
I really want to use BC as my main option to Clients but if they cannot log in and upload a blog post simply then what is the point of having it in the first place?
TOPICS
Content management and modules
Views
341
Translate
Translate
Report
Report
Community guidelines
community guidelines
Contributor , Mar 01, 2017 Mar 01, 2017
As an old Muse user, I have had experience with this. Best solution is to have an external stylesheet linked to your site.  In BC, go the ADMIN Panel, click on Develop, go to Stylesheets, and create a styles.css file (or name it whatever you want, just make sure to add .css as the extension).  Copy the file path - i.e. /stylesheets/styles.css.
In Muse, go to your Page Template(s), in the Page Properties, add <link href="/stylesheets/styles.css" rel="stylesheet" type="text/css">. Publish to site.
Votes
Translate
Translate
Contributor ,
LATEST
In Muse, go to your Page Template(s), in the Page Properties, add <link href="/stylesheets/styles.css" rel="stylesheet" type="text/css">. Publish to site.  Then using your newly developed stylesheet, create some css styles and apply them to your blog.
Personally, I would just create a "template" file in Muse, with the {tag_pagecontent} added, and use this template for your Blog, then do all of your blog styling in BC, this way you have better control of the layout, including css styling.
Votes
Translate
Translate
Report
Report
