12 Replies Latest reply on Jan 26, 2017 10:12 AM by holmesdtx
    Please help with EPS import to ID showing as gray lines in preview but black in PDF
      Hi. I was hoping you guys could shed some light on a display issue I am having.  Its not a real issue per se, but something that is bothersome.  In normal mode, and presentation mode (and all others for that matter), I have a isometric view of a product that is a placed EPS file, that shows up as gray lines instead of black.  When I export to pdf, the lines show correctly as black.
      Is there anyway to make the presention mode and normal mode show the lines as correct dark black like in the pdf rather than the light gray lines.  I am assuming the problem lies in the line weights, but I'm not sure.
      I'm using 2017 creative cloud indesign.  Btw, I think I see the same issues in illustrator.  In the program the lines show up as gray, but in pdf output, it is the correct black.  I've checked the options of appearance of black and that doesn't seem to make a difference.
      Any help would be greatly appreciated.  Cheers!!!
