1 Reply Latest reply on Jan 15, 2009 12:24 PM by mattvbo
    drupal and flex integration
    mtgna Level 1
      I have previously used DTO in Flex which is mapped to a PHP DTO file. I used PHP through remoteobject (AMFPHP) to retrieve info from a MySQL database which is converted into the DTO type and then passed back to Flex to populate Datagrid.
      The data used to populate the Datagrid is an ArrayCollection of DataVO, as follows.
      Public Function OnResult(event:Object):void{
      accountingdata:ArrayCollection = new ArrayCollection(ArrayUtil.toArray(event.result);
      I then used binding to populate a DataGrid with {accountingdata}
      then,
      selectedItem as DataVO
      The selected item on the DataGrid populates the variable selectedItem as follows.
      selectedItem = event.target.selectedItem
      I then populate textfields like so:
      date_txtfield.text = selectedItem.date
      accountno_txtfield.text = selectedItem.accountno
      I have no problem with this as the data from the server side are DataVO objects as well.
      However now I am trying to substitute my server side PHP scripts with Drupal contents/nodes (using Drupal as backend) and I am having conversion problems.
      I am not knowledgable enough to convert the data retrieved from Drupal into DataVO format.
      I can still populate the Datagrid using the ArrayCollection but I am not able to populate the individual textfields with invididual attributes such as date, accountno etc.
      As I am new to all this, could someone please provide instruction on how to do this (as detailed as possible)?
      Thanks!
        • 1. Re: drupal and flex integration
          mattvbo
          If you make a call to drupal, through the Actionscript Remote Object - you have to assign it a "return" function. If you put a breakpoint in that return function and run it you can see what the data looks like coming out of drupal. It's usually in an Object variable with all the properties setup to your return types.
          We've had great success parsing these objects directly from Drupal in our actionscript code.
          M@
