1. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
postrophe Jan 26, 2017 4:53 PM (in response to ChrisG66)Hi
Have you tried other "blending mode" ?
Pierre
2. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
ChrisG66 Jan 26, 2017 4:56 PM (in response to ChrisG66)I'm not sure what the other blending mode is?
3. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
ChrisG66 Jan 26, 2017 5:05 PM (in response to ChrisG66)Hello Adobe,
Why is my posted content rejected?
4. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
Mohammad.Harb Jan 26, 2017 5:09 PM (in response to ChrisG66)The layer you are trying to add gradient overlay on is empty ( Layer 4 is Transparent )
5. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
ChrisG66 Jan 26, 2017 5:16 PM (in response to Mohammad.Harb)That is correct. The layer is empty because when I click OK in the layer style menu, it doesn't create the gradation. So strange.
6. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
Semaphoric Jan 26, 2017 5:33 PM (in response to ChrisG66)Layer Styles are only applied to the non-transparent portions of a layer.
7. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
Nancy OShea Jan 26, 2017 5:34 PM (in response to ChrisG66)Layer Style Effects only work if that layer contains pixels. Either some solid color or paint strokes or something....
Use the Paint Bucket tool to add some color to that empty layer and you should see a gradient fill.
Blend Modes are near the top of your Layers Panel in a drop list. Normal is the default.
Changing Blend Modes can drastically effect results. Experiment to see what works best.
PS. Nice group picture.
Nancy
8. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
Semaphoric Jan 26, 2017 5:59 PM (in response to ChrisG66)1 person found this helpfulTry this: Make a circular Shape with the Ellipse tool, fill black with no stroke. Set the Fill to zero%:
Now add the Gradient overlay, and you can move and resize it using the Move tool.
9. Re: Gradient Overlay in Layer Style Not Showing Radial Gradient
ChrisG66 Jan 27, 2017 12:56 PM (in response to ChrisG66)Thank you all. I greatly appreciate the suggestions. I found out when I create a gradient adjustment layer I can move the radial gradation when the Gradient Fill menu is showing. I can also change the size and adjust my gradation level. Kind of tricky, but I figured it out. Thanks again for your help and time with this.
