4 Replies Latest reply on Oct 17, 2018 10:55 PM by willn35880056
    Reverse/mirror puppet
    Lupillo Arellano Level 1
      I have created a few character puppets, and their bodies all are three-quarters views facing to the right. If I want two of the puppets to "face" each other, how can I make one of the two puppets turn around... I want the puppet body to "reverse" or "mirror" itself, the opposite way of the way I originally created it? In this way the two puppets' bodies will face each other...
        • 1. Re: Reverse/mirror puppet
          KJerryK MVP & Adobe Community Professional
          One way I've found that works is to use the scale x function in the transform behavior. For instance, I did some twins scenes by dragging in two instances of the same puppet, scale x -100 on one of them, and animate each one separately. Using the *.puppet feature they can even be rigged differently in the puppet panel.
          • 2. Re: Reverse/mirror puppet
            Here's an example
            • 3. Re: Reverse/mirror puppet
              Thank you for your help!
              • 4. Re: Reverse/mirror puppet
                willn35880056 Level 1
                Heads up on using this method. If you have eye-tracking, it'll be backwards whether you're using the camera to track, the keyboard, or the mouse.  So, be aware you'll have to do all the eye tracking in the "wrong" direction, either before or after you mirror the character.
                Also, if you're character has any identifying features on one side (sword on his left hip or pocket-watch on his breast pocket) that'll be wrong, too.
                One of the major things I want to propose to Adobe is a method to mirror rigs.  Currently, I create all the layers in PS, then duplicate and mirror them, then I have a script this renames the layers from "Right" to "Left" and "Left" to "Right".   That way, the left arm becomes the right arm (or eye or leg or whatever) instead of the left arm being on the right side of the character after the mirror process.
                But, even then, you still have to manually re-rig both sides.  Seems to make sense to have a more automagic function for that.
                -Will
