7 Replies Latest reply on May 29, 2017 3:02 AM by sangeethak65390815
    Report for behind the text frame from rectangle or image
    selvam214 Level 1
      Hi All,
      How to find and report the hidden text frames, example the below text frame behind the rectangle frame.
      Note: we must ignore the grouped, anchored and wrap objects.
      The below sample is not working
      //An InDesign file with two objects on the same page,
      //one text frame and one rectangle that holds an image.
      var d=app.documents[0];
      var myImageContainerDup = d.allGraphics[0].parent.duplicate();
      var myTextFrameDup = d.textFrames[0].duplicate();
      //Make a selection:
      app.select([myImageContainerDup,myTextFrameDup]);
      //ID for New MultiStateObject: 83621
      //Adding a MultiStateObject (MSO) with the two selected objects:
      try{app.scriptMenuActions.itemByID(83605).invoke()}catch(e){alert(e);$.writeln("Something went wrong!");exit()};
      //The object in the front goes to state 1
      //The object in the back goes to state 2
      var myMSO = d.multiStateObjects[-1];
      //State 1
      $.writeln("Front:"+"\t"+myMSO.states[0].groups[0].pageItems[0].getElements()[0].constructo r.name); //=> "TextFrame" if text frame is in front
      //State 2
      $.writeln("Back:"+"\t"+myMSO.states[1].groups[0].pageItems[0].getElements()[0].constructor .name); //=> "TextFrame" if text frame is in the back
      Thanks in advance,
      Selva
