2 Replies Latest reply on Apr 13, 2017 6:19 PM by LeeC22
    Changing fonts causing crashes in various application modules
    LeeC22
      I had a ton of problems trying to get my CS3 to activate after a recent reinstall of my OS, I now have another problem. If I type some text into a text layer, and then try to switch fonts while that is active (i.e. deselect the text tool, reselect it, click the font name in the window, then switch with up & down cursors to do a live preview), after a small number of font changes, Photoshop hangs completely with a Visual C++ Runtime error that simply shows Program C:\... in the error dialog.
      When I have checked the system logs, I see different modules crashing.For example:
      Faulting application name: Photoshop.exe, version: 10.0.0.0, time stamp: 0x4601eae8
      Faulting module name: VersionCue.DLL, version: 3.0.0.78, time stamp: 0x45f02987
      Exception code: 0x40000015
      Fault offset: 0x0029bf97
      Faulting process id: 0x11a8
      Faulting application start time: 0x01d278a6b676a3a0
      Faulting application path: C:\Program Files (x86)\Adobe\Adobe Photoshop CS3\Photoshop.exe
      Faulting module path: C:\Program Files (x86)\Common Files\Adobe\Adobe Version Cue CS3\Client\3.0.0\VersionCue.DLL
      Report Id: 5a2c8619-e49a-11e6-8f86-90e6ba545534
      Faulting module name: AdobeUpdater.dll, version: 5.1.0.1082, time stamp: 0x45e646ef
      Fault offset: 0x00035e26
      Faulting process id: 0x10f0
      Faulting application start time: 0x01d278a676937c75
      Faulting module path: C:\Program Files (x86)\Adobe\Adobe Photoshop CS3\AdobeUpdater.dll
      Report Id: d4a8c49a-e499-11e6-8f86-90e6ba545534
      All of these are caused in the exact same way. I am tempted to reinstall my CS3 suite but after the massive problems I had just getting this working, I am hesitant to do so. I have a project partly completed and can't afford to be without CS3 but using the font previews like I do is a fundamental part of how I work.
      I deleted the AdobeFnt11.lst file at C:\Users\[UserName]AppData\Local\Adobe\TypeSupport and I have deleted the fontcache.dat file in Windows but the problem persists. I'm really not sure what else to try, so does anyone have any suggestions please?
        • 1. Re: Changing fonts causing crashes in various application modules
          Sahil.Chawla Adobe Employee
          Hi LeeC,
          Could you please refer to this link and let us know if it helps Troubleshoot plug-ins in Adobe Photoshop CS5 or CS4
          Regards,
          Sahil
          • 2. Re: Changing fonts causing crashes in various application modules
            LeeC22 Level 1
            Sorry for the late reply, things have been really busy lately and with things taking longer, time disappears faster.
            That link is for CS4 and CS5, this problem is for CS3, I don't quite see how any of that applies.
            However, I have run through all the settings resets, preferences clearing, CS3 re-installations I can think of. I ended up risking a re-install as this feature is a major part of my workflow, so it was worth the risk. It did not provide the solution though. The only workaround I am able to use, is inconvenient to say the least. I have to run Illustrator at the same time and make all font choices in that, because that doesn't crash when I do the exact same thing.
            But as I am sure you can appreciate, having to run two applications to change a font, is a bit on the extreme side. Before I had this licensing issue when I reinstalled, Photoshop has run with almost zero problems since the day I bought it. All of a sudden, I have to use CS4's licensing files to activate CS3 and I get this problem to boot.
