7 Replies Latest reply on Jan 28, 2017 2:26 PM by Eligijus Petrauskis
    Glow effect / seperate by color
    Eligijus Petrauskis Level 1
      Hello everybody
      I'm kinda new to the after effects, but I have worked and studied tutorials for a couple of days and I have hit the wall. I want to make a certain parts of my picture to glow. Red color to be exact. But I don't want my whole picture or mask to glow, my goal is to make certain element glow. See the pictures below:
      These dots are actually the snow from the picture:
      And obviously I don't want the snow to glow red only the "tissue" part.
      Any help would be much appreciated.
      Thank you
        • 1. Re: Glow effect / seperate by color
          By the way, I'm using After Effects CC.
          [Moved from non-technical Forum Lounge to specific Program forum... Mod]
          [Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
          • 2. Re: Glow effect / seperate by color
            Roei Tzoref Adobe Community Professional
            the way I understand you situation, you have a footage where the snow is embedded in the video so you can't separate the element from the snow. and you want that element to glow but not the snow... is that correct? show us the full shot - high quality unaltered frame so we can see exactly what you are up against. you might be able to create a matte based on color and contrast for the element separating the snowflakes from the element and then you can use an effect on the branch without it affecting the snow flakes.
            • 3. Re: Glow effect / seperate by color
              Thank you for the reply. Sorry for my long reply, unfortunately I work long hours.
              It's not a footage, it's a picture, I'm trying to make it alive( by glowing, snowing , hair moving etc.) it's my first pancake.
              What you did is quite nice.
              I tried to copy what you did, but now I have 3 pictures.(black & white, glowing, and original). but they don't overlap(blend) with each other.
              My composition doesn't have those little squares(see picture below) next to the file name.
              Oh and here's the original picture:
              http://wall.alphacoders.com/big.php?i=681016
              • 4. Re: Glow effect / seperate by color
                I tried to copy what you did, but now I have 3 pictures.(black & white, glowing, and original). but they don't overlap(blend) with each other. My composition doesn't have those little squares(see picture below) next to the file name.
                3 layers is correct. set your switches tab to show the transfer modes by pressing F4 or clicking here (1) or here (2) at the bottom of your timeline panel:
                now you have the transfer modes where you can set one layer to use the matte of another
                BUT WAIT
                if this is a still image, this would be much less trouble if you prepared everything in Photoshop before going into Ae:
                remove the snowflakes in Photoshop by using any one of PS's trademarks - the state of the art retouching techniques that are available for you (healing brush, stamp, etc.) also separating any other element you wish will be much easier with PS, instead of using AE's masks and mattes. after you are done, import the artwork to Ae and now you can create the glows and add snowflakes with any of the particle effects like CC Snow or CC particle world.
                also - this is a very big photo. what output do you have in mind? HD? 4K? are you planning to zoom in? this photo is 8k width - the more pixels, the harder Ae has to work to make calculations. you should make sure you bring your raster images as big as they need to be and no more than that.
                more about preparing your PS artwork to Ae here: https://helpx.adobe.com/after-effects/using/preparing-importing-still-images.html#preparin g_and_importing_photoshop_files
                • 5. Re: Glow effect / seperate by color
                  First of all, thank you a lot for your help.
                  I appreciate your suggestion to use photoshop but I'm just a self taught amateur and I can't afford all the candies at the moment. To be honest I'm still on my last days of trial on after effects. But I'm willing to buy 1 program for sure for starters. What would you suggest for me as my goal is to make pictures a bit more lively(adding glow and stuff) and put those pictures with audio.
                  Regards
                  • 6. Re: Glow effect / seperate by color
                    your CC trial includes ALL OF ADOBE products. you can use photoshop right now and finish this within a few hours. using After Effects with no supporting software like Photoshop, illustrator and Premiere will be very difficult for anyone and I would not recommend it.
                    if you want to use Ae alone, maybe in a hurry, then the method describer earlier will help you better isolate the glow from the snowflakes. you would still have the issue where you have snowflakes that are not moving.
                    quick methods for making a still more lively are:
                    1. add a flicker. try a preset called "Light leaks" - you can find it in the effects and preset's panel. create an adjustment layer and apply the preset to it, then adjust the controls to your liking.
                    2. add a wiggle - try the preset "wiggle-position".
                    3. overlay a vfx video - find an interesting light leaks footage (many on YouTube) and place on your still using the screen blend mode.
                    • 7. Re: Glow effect / seperate by color
                      Thanks for your support/suggestions. Much appreciated. I'll try things out and see what suits me best.
