10 Replies Latest reply on Jan 29, 2017 2:23 PM by riavandenbosch
    Lightroom
    riavandenbosch
      In Lightroom is er kleurverschil tussen een foto voor en n in de module ontwikkelen.. Waar zou dat aan kunnen liggen?
        • 1. Re: Lightroom
          Per Berntsen Adobe Community Professional
          A screenshot of the problem would be helpful.
          But it is possible that you have a defective monitor profile - try setting it to sRGB, or Adobe RGB if you have a wide gamut monitor.
          If this fixes the problem, you should ideally calibrate the monitor with a hardware calibrator.
          See https://www.lightroomqueen.com/articles-page/how-do-i-change-my-monitor-profile-to-check-w hether-its-corrupted/
          • 2. Re: Lightroom
            riavandenbosch Level 1
            Hello Per,
            I have chosen for srgb in my colormanagement. Now the colors are the  same.  Great!
            But my screen is an Eizo screen and I wonder why the profile after calibrating my screen and when I use that profile the colors are not the same in LR.
            Greetings, Ria
            • 3. Re: Lightroom
              So the profile you were using before changing to sRGB was created by calibrating?
              Then I guess that the profile had somehow become corrupted, and that you should calibrate again.
              It is always better to have a profile created with a hardware calibrator - it will be more accurate than sRGB or Adobe RGB.
              What model Eizo do you have, and what calibrator?
              And are you using the Eizo Color Navigator software when calibrating?
              • 4. Re: Lightroom
                Yes, the profile had somehow become corrupted. But I have calibrate it again and when I want to go from LR to PS there comes the message corrupt. Not when I use the sRGB profile. I wonder what is the problem.
                My Eizo is:CG223W and I always use the Eizo Color Navigator software with the Spyder 3 Pro.
                This is my profile
                Kalibreren van Eizo-scherm
                Start met het Eizopictogram (vlindertje)
                Create a new target                        next
                Monitornative              next
                Brightness                       100 (stond oorspronkelijk op 80)                  next
                White point                   D65              next
                Zwartpunt                       minimaal                        next
                Gamma      2.20             next
                R                                            2.20
                B                                            2.20
                Finish
                Naam geven                   Achter de naam die er staat een datum zetten. Create now
                Spyderpro op monitor plaatsen
                Proceed
                Save
                Exit
                • 5. Re: Lightroom
                  What have you chosen under Profile policy > Version in Color Navigator?
                  Lightroom has a problem with version 4 profiles, so if you chose version 4, try recalibrating with version 2.
                  See also Re: Lightroom and colormanagement with two monitor profiles
                  • 6. Re: Lightroom
                    Iam using version 5.3.0.3
                    I cannot find the profile policy.
                    • 7. Re: Lightroom
                      The latest version of Color Navigator is 6.4.15.3, so you should update.
                      There seems to be a problem with Color Navigator 5 and Spyder calibrators.
                      See post #12 in the thread I linked to above.
                      To get to the profile policy, start out by creating a new target.
                      Highliht an existing target, and click Create a new target.
                      Go through the process until this screen appears, and click Customize profile, which will bring up the screen I posted previously.
                      Then choose Version 2.2.
                      • 8. Re: Lightroom
                        So I can better update to the latest version instead of  2.2
                        How can I update this version in the colour navigator?
                        • 9. Re: Lightroom
                          • 10. Re: Lightroom
                            Thanks for all your information and help.
                            Colour Navigator is upgradet.
                            There is no corrupt profile in LR --> PS.
                            The colors in LR develop after import (bedore and after) are the same.
                            Great!!! Thank jou very much.
