• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Merged paths: lost subpaths and points with JSX
Contributor ,
Jan 28, 2017 Jan 28, 2017
Hi everyone,
I've created several paths
RmgdWS
Then I run this code to log the number of subpaths and points
for (var i = 0; i < activeDocument.pathItems[0].subPathItems.length; i++) {
    $.writeln("subpath: #" + i + "\t points: " + activeDocument.pathItems[0].subPathItems.pathPoints.length);
And I'm getting
subpath: #0 points: 4
subpath: #1 points: 4
subpath: #2 points: 4
Perfect. Then I do Merge Shape Components command and run the same code and I'm getting
Where're the other 2 subpaths? Or other 8 points?
I'm not sure if that's a bug or intentional, but is there a way to find these lost subpaths/points or maybe to un-merge the combined path?
Sergey
TOPICS
Actions and scripting
Views
599
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Jan 28, 2017 Jan 28, 2017
It seems to that I can see same issue.
I can't found this in DOM.
Anyway I like more action manager. You can do more with AM and you have better chance to see correct values. But it's more difficult.
If you want read values I recommend this:
GitHub - JavierAroche/descriptor-info: JSX module to recursively get all the properties in an ActionDescriptor used in A…
This can create object which looks like DOM approach but there is more properties. Anyway it is read-only. Example how to use it.
// Include t
Votes
Translate
Translate
Adobe
Enthusiast ,
GitHub - JavierAroche/descriptor-info: JSX module to recursively get all the properties in an Action...
// Include the JSON helper
#include "JSON.jsx"  // Include the descriptor-info module
#include "descriptor-info.jsx"     // ActionDescriptor example
var ref = new ActionReference();    //ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );    ref.putEnumerated( charIDToTypeID("Path"), charIDToTypeID("Path"), stringIDToTypeID("vectorMask") );    var desc = executeActionGet(ref);      // Retrieve its properties by running the getProperties function, passing the ActionDescriptor as a param  // Optional @param {Object} descFlags // Optional @flag {Boolean} reference - return reference descriptors. Could slighly affect speed. // Optional @flag {Boolean} extended - returns extended information about the descriptor.
var descFlags = {
     reference : true,
     extended : false
};   var descObject = descriptorInfo.getProperties( desc ); // If using descFlags > descriptorInfo.getProperties( desc, descFlags );   $.writeln(JSON.stringify(descObject, null, 4)); // Running in ExtendScript  // Running in Brackets with the Brackets-to-Photoshop extension // https://github.com/JavierAroche/brackets-to-photoshop // Brackets-to-Photoshop extension includes the JSON helper by default  $.writeln(descObject);
This forum sh** with my code, so here is undeformed form.
[JavaScript] // Include the JSON helper #include "JSON.jsx" // Include the descriptor-info - Pastebi...
You need place JSON.jsx and descriptor-info.jsx in same folder as you script (or place their content inside your script).
Then you can run:
descObject.pathContents.pathComponents[0].pathComponent.subpathListKey[2].subpathsList.points[3].pathPoint.anchor.horizontal
In: "subpathListKey" you should see your subpaths which are merged into one path inside path-layer. Paths which are not merged should be in "pathComponents"
Descriptor is for selected layer vector mask.
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
Ooooh, thank you so much, Jarda, I forgot to try to find the points with AM-code
Votes
Translate
Translate
Report
Report
