• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
RAID setup for PP/AE?
New Here ,
Jan 28, 2017 Jan 28, 2017
Hey all!
Quick question: I recently picked up an 8-bay Areca 8050T2. I also grabbed 8x 8TB Seagate IronWolf drives.
I'm wondering what the best RAID setup for PP/AE? I'm using a Mac Pro with a 1TB drive as well.
Should I do RAID 5? RAID 0 with constant backups? Something else? How should I set up PP/AE?
Second question, if you don't mind: can I put my raw files on the RAID and ALSO render to the same RAID, or will that cause performance issues?
Thank you all so much.
Views
338
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
RAID 3, or 30 and RAID 6 or 60 are great for sequential files like video.  Never use RAID 0 because it has no redundancy and do not use RAID 5 as it is slow on sequential files, really for high usage short files.
You might want to read what my dear departed forum friend Harm used in the past before extreme speed SSD's were available
Votes
Translate
Translate
Report
Report
New Here ,
Question, if you don't mind:
Isn't RAID 5 a "less parity-ed" version of RAID 6? Would it not be faster because you are writing 1/2 parity blocks than RAID 6?
Votes
Translate
Translate
Report
Report
LEGEND ,
RAID 5 is never recommended for video editing
Votes
Translate
Translate
Report
Report
New Here ,
Why is that?
(Not being argumentative, sincerely want to learn)
Votes
Translate
Translate
Report
Report
LEGEND ,
Did you read Harm's article?
I just checked it out and see that Harm did not use RAID 6/60 so I should not have mentioned it.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
many of the folks here are convinced raid 3 is the only option as its slightly faster for editing, but you can pick whichever raid fits your needs best. if you just want max performance with no data/drive protection you could do raid-0, but raid 5 wouldn't be a good option for data/drive protection with that many drives. instead, raid 6 is a good option as it should be able to loose two drives and recover. the extra parity in raid 6 should be more robust with any bit rot (file corruption). raid 30/50 can loose two drives, but not two in the same raid 3/5 subset and the parity isn't shared across all 8 drives. raid 10 is even more robust, but would loose half the total capacity.
if the data that will be placed on the 8-bay Areca 8050T2 is important or critical, it should be backed up to another copy/location as well. a nas, single external drives, the internet/cloud etc. when buying lots of drives at the same time, they are mfg'd at the same time and multiple can fail at the same time. so its not unheard of to have a raid built to handle 1-2 drive failures go completely down when 2-3+ fail at the same time, or more fail when the raid is trying to rebuild/recover from the first lost drive(s).
Votes
Translate
Translate
Report
Report
Guest
Jan 30, 2017 Jan 30, 2017
LATEST
I think RAID 0 is probably not the best answer to speeding boot and loading times in 2011.
Solid State Drives [ SSD's] use memory chips rather than moving disks .
The OCZ vertex 3 series drives , or OCZ revodrive 2 will run many times faster than a RAID array .
Capacity is limited [ by cost] so most people use them as boot drives and storage for current projects , and add a back up hard drive or two for data storage .
Votes
Translate
Translate
Report
Report
