• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
what's the different for adobe pdf presets and print presets
Community Beginner ,
Jan 29, 2017 Jan 29, 2017
Hi everybody,
I'm new for using indesign,
actually, I try this two ways to export pdf before, same setting(may be)
but can't find out any different,
so I want to learn more about this,
when use adobe pdf preset, or when use print preset?
Views
743
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jan 29, 2017 Jan 29, 2017
Distiller is way too old to use for print workflows these days. Among other reasons: It doesn't support transparency; it doesn't support color management; strips out all tagging so it could be repurposed or support accessible screen readers; it doesn't support layers...
You should also choose File > Export > Adobe PDF (Print) and choose the appropriate PDF preset.
Here's a link to an article I wrote 11 years ago which is still true:
http://indesignsecrets.com/creating-pdf-export-or-use-distiller.php
Votes
Translate
Translate
Community Expert ,
Pretty simple: If you're using File > Print, you can create and use a Print Preset. If you're creating a PDF with File > Export > Adobe PDF (Print) you can create and use a PDF Preset.
You might try reading more in InDesign Help.
Votes
Translate
Translate
Report
Report
ah.....sorry....my mistake!
I mean print preset also can create pdf,
I define the new rule "HIGH" setting for create pdf
and I try to use adobe pdf preset to create pdf
use the "HIGH" setting too
I think there was no difference
may be the one different just print preset through Distiller to create pdf?
Votes
Translate
Translate
Report
Report
Community Expert ,
Don't use Distiller to create a PDF, that's an obsolete workflow.
What's the purpose of your PDF: an Interactive PDF, for commercial litho printing, for a desk-top printer or for document circulation?
Votes
Translate
Translate
Report
Report
dear Derek,
its for commercial litho printing actually,
so nobody to use Distiller now?
I just try to learning their different to decided use which is better.....
Votes
Translate
Translate
Report
Report
Community Expert ,
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Unless you've been given a spec by your printer, use the InDesign Acrobat PDF Presets and select PDF/X-4.
(Ensure you're working in a RGB colour mode, such as sRGB and ask your printer if they want trim marks, which you can indicate by ticking Use Printers Marks in the Export PDF dialogue box.)
Votes
Translate
Translate
Report
Report
