• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Grid View in Library Module is scrollable left to right/offset
New Here ,
Jan 29, 2017 Jan 29, 2017
Hi everyone,
im having a problem with Lightroom CC (latest update and also on previous versions) on my MacBook Retina:
If i pinch on the trackpad to resize the Grid View in the Library module, scrolling isn't restricted to up/down but im able to scroll it left to right. The grid then gets offset to the side, so the left columns of pictures then gets pushed outside the screen (see screenshot). At first i thought this might be caused of my changed display resolution, but changing that does not solve my problem, sadly. Manipulating the grid size via keyboard shortcuts does NOT have the same effect. Seems to be a problem with trackpad or sth.
Im on OSX 10.10.5 Yosemite, Macbook retina is a 13" late 2012 (2,5 Ghz i5, 8GB RAM, Intel HD 4000 GPU.
thanks in advance,
Ronny
Views
276
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here , Feb 02, 2017 Feb 02, 2017
Hi Akash,
thanks for your answer. After resetting the issue still happens to be present, although clicking on an image then resets the gird to the correct position on the screen.
Changing the display resolution does not affect that problem sadly, but nonetheless, the display resolutions I use are as follows:
1. 2560x1600 @232 dpi (
2. 1280x800 ("optimal for screen" in Preferences)
3. 1680*1050 (upscaled in System Preferences)
Regards,
Ronny
Votes
Translate
Translate
Feb 01, 2017 Feb 01, 2017
Hi Ronny,
What is your Screen resolution and DPI settings on your computer?
Try restoring Lightroom preferences after backing up your catalog following Resetting Preferences in Lightroom CC/6
Let us know if that helps.
Regards,
Akash
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Hi Akash,
Regards,
Ronny
Votes
Translate
Translate
Report
Report
